Offroad & 4x4
Ford bed bob 4 link
Old Jan 10, 2009 | 11:24 PM
Blueoval_boy_64's Avatar
Blueoval_boy_64
Ford bed bob 4 link
Well here's the rear suspension fit up on the ford. let me know what you guys think
Side view
Inside view
Rear view
Inside looking back
Old Jan 10, 2009 | 11:42 PM
RawPower's Avatar
RawPower
Fabrication looks good. However, you can't really tell how it will function without seeing some anti-squat, roll-axis, etc. calculations & numbers...
Constructive criticism:
I'd gusset/brace/box in the coil mounts. I do prefer over building, others may think that folding will not be an issue.
Looks like your rod ends are too far out of the links... ie you have exposed thread. I'd be afraid of bending them. If your links are too short, a cheap solution is to put on lock nuts. This essentially just stiffens the RE shaft by adding support. Then again, I might just be seeing things, I'm not sure.
Old Jan 11, 2009 | 04:15 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
Need full on side iew of the truck!!!
Old Jan 12, 2009 | 12:22 AM
Prozon's Avatar
Prozon
It <i>looks</i> pretty good. You did a really good job on the bed bob too.
Keep up the good work!
Old Jan 12, 2009 | 08:34 AM
Ryan50hrl's Avatar
Ryan50hrl
can we get higher resolution pictures....jeez...how are we supposed to rip on your welding if we can't see it....LOL
Old Jan 12, 2009 | 11:15 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Not ripping, just wondering why you left the rear pinion angle flat? Did it have to do with mounting the 2 joints on top of the diff?
Old Jan 12, 2009 | 12:02 PM
Blueoval_boy_64
Yea it really helped with how I mounted the upper links and for how long the driveline will be it really wont be that bad on the angle. I'll get some better pics this week after I can roll it out of the shop
Old Jan 12, 2009 | 03:52 PM
crazyredneckanyhow
Remember this is not Pirate. Please be nice to all the other children.
Old Jan 12, 2009 | 08:37 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
So if you see a truck, Looks kinda similar to yours, parked where yours should be, but its a long bed, white and grey, mostly stock except for some 37"s....
I DONT KNOW WHO HAS YOUR TRUCK!
Nice ride, hopefully mine will be that clean when im done with it.
Old Jan 20, 2009 | 04:42 PM
Blueoval_boy_64
So I tried to flex my suspension out yesterday... but it turns out my tractor would only lift it 35 inches in the rear... but here's what it did. The bed looks like it's about to fall off because it was about to. Haven't got to redrill the holes for the new bed so my
brother was holding it in place.
view from the rear
View from the front
I may only be 5'7 but it's still somewhat impressive since it's flexing this much on 44's
Old Jan 20, 2009 | 04:52 PM
hav24wheel's Avatar
hav24wheel
looks to me, that most of the flex is in the frame...... but could just be the picture..
Old Jan 20, 2009 | 04:54 PM
Blueoval_boy_64
Mostly the picture. I'll try to get some better pictures after I have the bed bolted down and something bigger to pick it up with
Old Jan 20, 2009 | 08:47 PM
texastech_diesel
Token Redneck
Nice job
Old Jan 20, 2009 | 09:11 PM
Ryan50hrl's Avatar
Ryan50hrl
That frame needs some boxing......but very nice work....
Old Jan 20, 2009 | 10:14 PM
Blueoval_boy_64
It's going to get fully boxed... but I need the dual transfercase plate first so that I can just do all the boxing/fabricating on the new crossmembers at the same time. Just waiting on parts now
