CCV Mod
Old Jan 13, 2009 | 10:21 AM
mblanken881's Avatar
mblanken881
Thanks Adam
Old Jan 13, 2009 | 10:36 AM
Adam0331's Avatar
Adam0331
Yea sure, I haven't noticed anything bad with just leaving it hang there. So far so good and it's been about 6 months now.
Old Jan 13, 2009 | 11:10 AM
superduty4x4's Avatar
superduty4x4
My CCV mod is not mounted to the factory bracket either... no need for it really. If you get bored and feel like fabbing one up go for it, but don't sweat not having one.
Old Jan 13, 2009 | 11:38 AM
jdecker88's Avatar
jdecker88
Here is a picture of mine and I run a little filter from Ron on my CCV
Old Jan 13, 2009 | 11:58 AM
superduty4x4
OOooooooh purdy! Have you ever tried the wastegate delete mod? I still need to rig a filter on my CCV... catch much in yours?
Old Jan 13, 2009 | 02:20 PM
jeff7825's Avatar
jeff7825
That's clean Justin. I think that Rick still has you beat though. Is your filter in the picture? If so, I don't see it.
Old Jan 13, 2009 | 08:32 PM
mblanken881
What hose should I buy for this mod? And where do I get it? All I need is one 90* fitting. Correct?
Old Jan 13, 2009 | 08:41 PM
fxstbchopper's Avatar
fxstbchopper
Yes a 3/4" 90* and some 3/4" heater hose you should be able to get at any auto parts store the amount will depend on how far you want to run it out.
Old Jan 13, 2009 | 10:23 PM
jdecker88's Avatar
jdecker88
Well my engine bay is cleaner now I washed it the other day but I do not have any pictures of the filter but here is Rons
Old Jan 14, 2009 | 09:53 AM
superduty4x4
Where do you hide that big some beach JD?
Old Jan 14, 2009 | 10:55 AM
jdecker88's Avatar
jdecker88
It was right beside my 6637 but I moved it now its right against the firewall.
Old Jan 14, 2009 | 11:30 AM
strokersace's Avatar
strokersace
Used 4" exhaust pipe also. I wanted a factory look still, so I welded a piece of flat bar on it to mount like the original one, then painted it black.
Here's on of the whole engine compartment. Sorry it's from farther away, but you still can't tell anything has changed on the CCV.
If you're not as picky as I am, then just cut some extra from your exhaust, clean the burrs off the edges and install!
Old Jan 14, 2009 | 11:45 AM
  #28
superduty4x4
Ryan are you running an early 99 intake hose on your 02?
Old Jan 14, 2009 | 11:57 AM
  #29
strokersace
Don't know for sure. I'm guessing you're talking about the hose between the CCV and the filter? When I bought my Tymar it came with the mandrel bend 45* pipe, the connection hose, filter, etc. So I guess it could be.
Old Jan 14, 2009 | 12:02 PM
  #30
superduty4x4
Yep. And it looks like an early bird intake hose, my guess is Dale goes that route because with the late style setup there wouldn't be much room for putting the filter minder where he has it, plus it would be hard to get that same angle with the late style intake (looks like more clearance with his setup).
