rear brake calipers
Old Jan 10, 2009 | 10:50 AM
pete315's Avatar
pete315
rear brake calipers
I have a 97 Explorer with rear disc. do I need that special tool that turns the piston as you press the piston in on the caliper or does this year have the emergency rear brake shoes so I can just push the piston right in like the fronts?
Old Jan 10, 2009 | 12:10 PM
aquanaut20's Avatar
aquanaut20
My 97 has a separated brake drum inside the rear disk hub.
Last time I checked, the drum brake shoes were paper thin, not designed for stopping the vehicle, just holding when stopped.
Recommend opening bleed screw when resetting piston, this will allow fresh fluid to fill caliper when you apply initial pressure (also no dirty fluid is pushed back up system)
bigtexan99
Oct 24, 2014 01:14 PM
98SurplusExpy
May 25, 2012 08:19 AM
Tacohead
Mar 22, 2009 09:04 AM
Piper106
Oct 30, 2005 03:42 PM
billwane
Jan 4, 2004 06:31 PM
