86 F150
Old Jan 9, 2009 | 11:07 PM
stringbean333's Avatar
stringbean333
86 F150
steering has alot play,i was thinking steering linkage,balljoints,tierods,bushings,anyone have any thoughts?
Old Jan 10, 2009 | 01:52 AM
hittman1422's Avatar
hittman1422
if they havent been done lately do it... not to expensive and you dont need any exotic tools to do so... if shocks are bad might as well do them while you're at it, wheel bearings also. oreilly's has all the parts for under 400. word of warning though, borrow a press from oreilly's not a friend. if the ball joints are really bad like mine were you MIGHT spread the press.... especially if its a chinese POS. but yeah if that hasent been done and you want a better ride along with tighter steering, shocks tie rods, bearings, balljoints, all help tremendously!
Old Jan 10, 2009 | 08:20 AM
scottddove's Avatar
scottddove
I suggest instead of thinking what it might be. Why not have a friend sit in the drivers seat and crawl under your truck and find out what it is by having the friend turn the wheel back and forth and look for where the play is at. I replaced the tie rod ends on my truck not long ago and it now drives like new. If you do this you will need a front end alignment. Mine is a 86 f 150 as well. parts cost around 150, alignment was 35. good luck.
Old Jan 11, 2009 | 12:43 PM
stringbean333
hitman1422 and scottddove
thanks for the info
Old Jan 11, 2009 | 01:02 PM
stringbean333
thanks for the info
Old Jan 13, 2009 | 09:45 AM
johnfl's Avatar
johnfl
Check the rag-joint where the steering shaft attaches to the steering box. Mine is shot and looks to account for about 1/2 the slop in my steering
JohnF
zombiefied 247
Oct 30, 2012 04:58 PM
deadeyedevon
1978 - 1996 Big Bronco
15
Jan 4, 2010 06:12 PM
tetraruby
Nov 18, 2002 07:12 PM
Drawsoncad420
Jun 13, 2002 04:43 PM
94 ford
Aerostar
Apr 29, 2002 11:43 AM
