Alternator Light Flashing W/O Load
Old Jan 9, 2009 | 09:18 PM
78FordTruck78's Avatar
78FordTruck78
Hi All
I'm wondering what suggestion some of you may have on why my alternator light flashes when there is not a load. It flashes continuously until i turn on the heater, headlights, etc.. Could this be a time to replace the V/R? Before this was going on all my lights in the truck would seem to have a pulse and they still do. Anyone have thoughts on this?
Old Jan 9, 2009 | 09:40 PM
fmc400's Avatar
fmc400
MSEE
Check to make sure that you have a solid ground strap between sheetmetal (firewall is the most common) and the block. The regulator grounds through its mounting flange, so the inner fender well must have a solid return path to the block.
Old Jan 9, 2009 | 09:43 PM
78FordTruck78
I'll go out and check all of the grounds. Thanks
Thunderduckie
Nov 15, 2013 10:26 PM
bcaughhorn
Sep 3, 2013 11:45 AM
k9trainer
Jan 3, 2013 11:35 AM
joshofalltrades
Electrical Systems/Wiring
Aug 7, 2012 06:56 PM
rustyfender
Apr 16, 2003 10:00 PM
