2000 heat issue
Old Jan 9, 2009 | 06:42 PM
Xerophobic's Avatar
Xerophobic
2000 heat issue
Ive done a fair bit of reading here and have tried to use the search function as much as possible but havent found the solution.
Just bought a US 2000 excursion V10 and it seems good except it does not appear to blow very much heat from the dash vents or defrost.
ive read alot about the blend door but am not fully satisfied I want to tear the dash apart just yet.
The AC does blow and I CAN hear the workings "change" as I rotate the dial from cold to hot.
I CAN get the air to blow out of everywhere its supposed to.
The heatercore lines inside the dash/around the heaterbox behind the glovebox DO feel quite hot.
So where exactly is the blend door on an excurions and what should I do before I get heavily into something that may not be the problem.
I do get heat from the vents/defrost but its just luke warm at best
(the rear system seems to blow hotter than the front)
Thanks
Old Jan 9, 2009 | 08:01 PM
Cardiac69's Avatar
Cardiac69
Can't help you with the blend door (Gotta be near the heater core), but there are some alternatives in this thread: https://www.ford-trucks.com/forums/8...er-months.html.
Good luck with it, hope you figure it out.
Old Jan 9, 2009 | 09:39 PM
jdarchie's Avatar
jdarchie
Congrats on the purchase... I just bought my first X also. Only has 173 k on it... Your problem sounds like a sticky or low temp thermostat. That is the cheapest answer i have for you.
Old Jan 10, 2009 | 10:31 AM
Xerophobic's Avatar
Xerophobic
between the white operating range marks . Do others Ex's run warmer than that?
Thanks for the replies guys.
I should mention on the drive home I towed a 31 scarab 1800 plus miles and the temp guage never moved. It seems to settle in at about 25% to 33% of the way
Old Jan 10, 2009 | 03:56 PM
Xerophobic's Avatar
Xerophobic
No clue why it jumbled my reply there altho I did post from a blackberry phone. Should have read.....
I should mention on the drive home I towed a 31 scarab 1800 plus miles and the temp guage never moved. It seems to settle in at about 25% to 33% of the way between the white operating range marks . Do others Ex's run warmer than that?
Also the rear seems to blow warmer than the front which is why Im suspicious of the blend door. It does work to some degree as I can get nice cold AC too tho. I really dont want to pull anything apart to find its not a problem!
Old Jan 11, 2009 | 05:26 PM
whjco's Avatar
whjco
That's about where my gauge runs, although you'll find postings about the temp gauge where the thermostat was replaced and the heater started working better but the indication on the gauge didn't change.
Is that '31 Scarab what they called something like a Scout Scarab that was real streamlined? Kind of like a sausage with tires? Those are really rare!
Old Jan 11, 2009 | 05:46 PM
Xerophobic's Avatar
Xerophobic
I think the next step is a thermostat just cause its relatively cheap and easy
I'm not totally sure what u mean about the Scarab but ill post a pic
Old Jan 12, 2009 | 01:21 PM
Xerophobic's Avatar
Xerophobic
Scarab behind the "new" Ex
ballow97
Feb 17, 2014 01:31 PM
TobyM
Nov 13, 2013 10:33 PM
62uni4x4
Sep 21, 2012 08:07 PM
f100guy
Dec 24, 2004 10:29 AM
