86 f-150 302 efi problems
Old Feb 3, 2009 | 12:25 PM
johnfl's Avatar
johnfl
Originally Posted by gofastl
Ya the fordfuelinjection site says there is a white and black one and gives the voltage reading too. I would like to just get rid of it all and be done with it.
Yeah, me too but in The Peoples Republik of California you get sent to the re-education camps for that sort of thing.
JohnF
Now of ARIZONA !!!!....which is, sadly, slowly becoming a satellite state of California
Old Feb 3, 2009 | 12:50 PM
Franklin2's Avatar
Franklin2
The only way you could do that would be to get a aftermarket fuel injection system, something like the hot rod guys use. There is also a system called "Megasquirt" that you can build yourself, but it's pretty involved and a lot of reading and computer stuff.
The Ford system is not too bad, and at least the computer will talk to you and tell you obvious problems it sees. If you do not get any codes, then start with the basic stuff like fuel supply, vacuum leaks, and timing.
Old Feb 3, 2009 | 03:44 PM
gofastl's Avatar
gofastl
Ya the MS, BS3, tweecer looks real confusing. But kind of nice to go in there and switch stuff around to get that extra edge if ya know how to do it. Speed density doesnt give you alot of expandability. Ill see what codes I can get when the engine is running and than maybe check vacuum lines and such.
Joejustatruck
Oct 24, 2012 11:49 AM
flatheadjohn
Jan 27, 2012 07:05 PM
Eightyfive Flareside
Oct 26, 2011 06:47 PM
blackmajikf100
Dec 12, 2010 09:02 PM
78F150XLT
15
Apr 24, 2008 12:38 AM
