Aerostar Ford Aerostar
Adjusting rear hatch
Old Jan 8, 2009 | 07:37 PM
vwhed1979's Avatar
vwhed1979
The rear hatch on my van doesn't line up correctly. I have tried to align it, but it doesn't seem to budge when I loosen the bolts. I am afraid to put too much force on it when the bolts are loose. Is it possible to adjust this way? Are there any special tricks to it?
Old Jan 9, 2009 | 03:47 AM
Pablo-UA's Avatar
Pablo-UA
no. to loosen bolt only. try some wd-40 from undreneath.....
some heating ))) kidding of course!
Old Jan 9, 2009 | 10:46 AM
96_4wdr's Avatar
96_4wdr
AutoZone.com | Exploded view of the rear hatch hinge assemblies
ALIGNMENT
The hatch can be adjusted side-to-side and up-and-down by loosening the hinge-to-header attaching nut. Adding spacers permits in or out adjustments as required. The hatch should be adjusted for an even and parallel fit with the door opening. Tighten the nuts to 13-20 ft. lbs. (17-27 Nm).
The striker assembly can be moved 1/6 in. (4mm) radially (side-to-side/back and forth) as necessary. Tighten the striker to 30-40 ft. lbs. (41-55 Nm).
CLINT-THE-GREAT
Feb 14, 2013 08:17 PM
1997 Expedition EB
Oct 28, 2010 06:20 PM
TheBludgeon
May 3, 2010 08:47 AM
2005EXCURSION
Apr 14, 2009 02:31 AM
chrison600
May 18, 2003 08:51 PM
