DP Tunes, Boost and 6637 - Noise?
Ok, new to the DP Tunes. Love them. But I have questions.
I have my 6637 mated to 3.5 inch length of 4 inch pipe connecting the filter and the intake pipe. Never had a problem with that.
Now, on 80e or 140 smoke when I get on it (or mainly when ease off of it), I get a squeek..squeek...squeek sound (hard to explain but almost sounds like tires chirping) it is definitely coming from the engine side of my firewall right in front of me. I've wondered if I'm hearing air being sucked around my 4 inch pipe where the rubber intake is clamped down to it. I've tighened as much as possible.
Anyone else ever heard this under boost (hitting 25-30 lbs according to gauge)? Could it be something else. I've heard all descriptions of turbo surge and this doesn't sound like that (turbo still whistling away)...although I'm wondering if it could be the air taking the easiest way back out of my filter and making this strange noise.
I once had a leaky joint on my up pipes and when I would get on it,it would make a chirping,kinda like a policemans whistle kinda sound( I know thats alot of kindas...whew)if thats a possibility have someone rev on it while you look under the hood at the rear of the engine bay behind the turbo,if the up pipes are leaking,you'll see black smoke.Just my .02 worth
Schlepprock
Schlepprock
I definitely have a small up-pipe leak but since I can hit 30 psi boost, I didn't figure the leak was too bad, but.....maybe that is what this noise is. If I had to pinpoint an exact location...it sounds like it is coming from under the dash around the steering column area....which would match up with the up-pipe leak I suppose.
The needle isn't bouncing that I can tell. I also noticed tonight that it does it most at around 20 psi boost...again...as i either back out or keep it level at that point...any more pedal and it stops making the noise.
