6637 Question
Old Jan 7, 2009 | 04:37 PM
gappy's Avatar
gappy
6637 Question
I'm putting my filter in and was wondering what to do with the sensor that is in the old air box. Just leave it hooked up once I remove the box?
What is this sensor?
Old Jan 7, 2009 | 04:39 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Yes. Leave it connected but zip-tie it to the brake lines or something close by to keep it out of the way.
Old Jan 7, 2009 | 04:57 PM
superduty4x4's Avatar
superduty4x4
What Brendan said. It's called the IAT, or intake air temp sensor.
Old Jan 7, 2009 | 05:03 PM
jdecker88's Avatar
jdecker88
Thats what I did on both of my last installs and it never caused a problem.
Old Jan 7, 2009 | 05:13 PM
rblaine9000's Avatar
rblaine9000
I drilled a hole in my 4" pipe and took a rat tail file and filed two grooves so my sensor would fit. I have'nt had any problems and it is functional more so than if it were dangling beside the filter
Edit...what I mean 4 inch pipe... this is the pipe that I used to adapt to my filter out of exaust pipe
Old Jan 7, 2009 | 05:15 PM
superduty4x4
Nice job and very true, however the IAT does very little to affect how the truck runs.
Old Jan 7, 2009 | 05:24 PM
Bowie's Avatar
Bowie
Is this the filter minder? OR something else. I saw someone put it on the end of the filter, i think.
Old Jan 7, 2009 | 05:25 PM
Bowie's Avatar
Bowie
I am about to do this change too, just waiting on the filter.
Old Jan 7, 2009 | 05:26 PM
superduty4x4
On the later trucks you'll have to do something with the filter minder, if it has wires going to it then it needs to stay. Mine didn't so it's gone. Someone on here had found a piece of tubing with a fitting for the filter already in it from the aftermarket somewhere...
Old Jan 7, 2009 | 06:28 PM
whjco's Avatar
whjco
I've found the filter minders to not be too reliable so I didn't bother putting it back on when I did the 6637 mod. Since you can look right at the filter, it's kind of pointless anyway.
Old Jan 7, 2009 | 06:31 PM
superduty4x4
Bingo, but the problem is on the newer trucks (02-03 I believe) the filterminder is a sensor of sorts- it has wiring going to it and if you run without it you set off some kind of light on the dash and store a code.
Old Jan 7, 2009 | 06:32 PM
87 F-150 I6's Avatar
87 F-150 I6
Zip tied both the filter minder and the AIT on one of the break lines. Not a problem at all.
Old Jan 7, 2009 | 06:52 PM
gappy's Avatar
gappy
I finished already......easiest mod ever.
Now I need to get one those cool pre-filter bags.
Old Jan 7, 2009 | 06:56 PM
superduty4x4
Indeed, the prefilters are trick! Home
Old Jan 7, 2009 | 07:00 PM
trike1946's Avatar
trike1946
What did you all use for the short pipe? I could not find a piece of plastic pipe to fit.
