O2 sensor
Old Nov 26, 2002 | 03:39 PM
KJKozak2's Avatar
KJKozak2
O2 sensor
Old Dec 8, 2002 | 11:33 AM
robnooy's Avatar
robnooy
O2 sensor
What does a O2 sensor read, the volume or the percentage of oxygen. dual exhaust with the O2 in one pipe and my performance dropped. Would an h-pipe help. and would running a single wide pipe with the O2 after the y-pipe help any.
gotta burn gas to make noise
Old Dec 8, 2002 | 01:29 PM
MustangGT221's Avatar
MustangGT221
O2 sensor
Whenever you have dual exhaust you need to have an H-pipe because it evens out the exhaust on both sides. The stock application has a small H-pipe with the o2 sensor in it. I would suggest an H-pipe close to the size of pipe that you used and weld in an o2 sensor bung and your off.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 8, 2002 | 01:32 PM
MustangGT221
O2 sensor
By the way,
Say if you unplugged the o2 sensor, the computer doesn't get a reading and it will automatically richen the fuel mixture, causing the bad gas mileage. If you are only reading from 1 side of the engine, the o2 sensor probably doesn't have a proper reading, and that might be your problem, it's richening the mixture.
Franklin2
Apr 26, 2023 07:29 AM
IB Tim
Oil & Lubrication
May 15, 2013 02:22 PM
Franklin2
Jan 3, 2002 08:02 PM
Franklin2
Feb 7, 2001 12:12 AM
PAUL_2
Oct 19, 2000 04:20 PM
