Water Pump?
Old Jan 7, 2009 | 02:40 PM
Booost's Avatar
Booost
Water Pump?
Hey guys,
A friend of mine just called asking about a problem with his 2000 7.3L. He was driving, then heard a clunk and said he lost his power steering, and brakes. He said the radiator fan pulley still has the belt attached, but the fan is cocked a bit towards the drivers side...and the water pump is leaking antifreeze. Would this be the water pump? I was entirely unsure after searching.
Thanks!
Old Jan 7, 2009 | 02:45 PM
lancer's Avatar
lancer
Tell your freind to grab hold of the fan and wiggle it. If the shaft in the water pump moves the bearings are shot. From what you say it sounds likr thats most likely the prob. There not to bad to change.
Old Jan 7, 2009 | 02:47 PM
Booost's Avatar
Booost
Sounds good...he said there was definately a bit of play.
Old Jan 7, 2009 | 02:51 PM
ITA47's Avatar
ITA47
If you have a CarQuest near you they sell the Airtex (new) waterpump that everyone recommends with a lifetime warranty. Make sure you get the lower hose for that pump as the lower attchment is different than most stock pumps. The lower hose is about $12. Good luck!
Old Jan 7, 2009 | 02:52 PM
rugermack's Avatar
rugermack
Sounds like the pump, I installed a rebuilt one first and it lasted 25k, then I bought one of these pumps, they are the same ones the dealer sells for $300. Mine has 85k on it now, good pump. www.northernautoparts.com
Airtex Ford, Jaguar & Mazda Water Pumps
<TABLE cellSpacing=1 cellPadding=5 width="100%" border=0><TBODY><TR><TD vAlign=top>E-MAIL THIS PRODUCT TO A FRIEND
Price: $94.99
1996 - 2003 Ford 7.3L Turbo Diesel engines. This pump fits the 1996 through 2003 model Direct Injection Turbo Diesel models. Pump contains new bolts, plugs, gasket and installation instructions!
<TABLE style="FONT-SIZE: 8pt; WIDTH: 494px; HEIGHT: 97px" height=97 cellSpacing=1 cellPadding=1 width=494 bg*************** border=0><TBODY><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
Make
</TD><TD>
Model
</TD><TD colSpan=2>
Year
</TD><TD>
Application
</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #f5f5f5" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
FORD TRUCK
</TD><TD>
E100- E350 Super Duty, E450,
E550 and E Super Duty Vans
</TD><TD colSpan=2>
03-96
</TD><TD>
V8 446 (F) (7.3L) (Diesel)
</TD></TR><TR onmouseover="this.style.backgroundColor='#f5f5f5'; " style="BACKGROUND-COLOR: #ffffff" onmouseout="this.style.backgroundColor='#FFFFFF'"> <TD>
FORD TRUCK
</TD><TD>
Excursion
</TD><TD colSpan=2>
03-00
</TD><TD>
FORD TRUCK
</TD><TD>
F100, F150, F250, F350 Pickup
</TD><TD colSpan=2>
97-96
</TD><TD>
FORD TRUCK
</TD><TD>
F250/350/450/550 Super Duty Pickup
</TD><TD colSpan=2>
03-99
</TD><TD>
FORD TRUCK
</TD><TD>
</TD><TD colSpan=2>
1997
</TD><TD>
V8 446 (F) (7.3L) (Diesel) VIN F
FORD TRUCK
</TD><TD>
</TD><TD colSpan=2>
1996
</TD><TD>
FORD TRUCK
</TD><TD>
F59 Stripped Chassis
</TD><TD colSpan=2>
97-96
</TD><TD>
F59 Stripped Chassis (Diesel)
</TD></TR></TBODY></TABLE>
Category:
Water Pump, Gskt, Fan & Clutch
Manufacturer:
Airtex Water Pumps
Model Number:
AW4114
Old Jan 7, 2009 | 02:57 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
While he's doing that, have him (if he doesn't already) get a new upper radiator hose. The one use for the dual alternator setup goes behind & around the serpentine belt. The original style hose passes through the serp. belt. What that means, is with the original/old style hose, to change out the serpentine belt, you must disconnect the upper hose! No good! With the new style/dual alternator hose, you can remove the serpentine belt without needing to remove the hose. Napa carries them if CarQuest doesn't, but I'd highly recommend it.
Old Jan 7, 2009 | 06:00 PM
camodown's Avatar
camodown
might as well replace the thermostat and gasket while you're in there. Also make note of where the bolts holding the pump on go. They are different lengths. Youll want the special fan clutch tool from your auto parts store as well...
Deerhunter76
Feb 1, 2014 07:35 AM
Redneckfordf2502002
1983 - 2012 Ranger & B-Series
Mar 26, 2013 01:50 PM
ech0sh4y
2004 - 2008 F150
Nov 8, 2007 07:48 PM
BajaRacer909
Modular V10 (6.8l)
Dec 28, 2005 09:37 AM
