Oil & Lubrication
micro lubes! do they work?
Old Jan 6, 2009 | 08:01 PM
chillmiller's Avatar
chillmiller
we have all been watching powerblock and heard of them
seen shelby sittin next to a gt500 ss stage 2 with a bottle of z-maxx
seen the horsepower guys "testing" px3 on dynos
seen the dyno test on sites here people rave up and down about it
but dose it work!
will it actually give you more hp better mpg
or are they just blowin smoke up our tail pipes
is the best way to go a really good oil like mobil1 syn or castorl syn
what do you think?
Old Jan 6, 2009 | 10:05 PM
cjben's Avatar
cjben
in my opinion,they do work for what they were designed to do,which is make your wallet lighter.
Old Jan 16, 2009 | 01:27 AM
bruce381's Avatar
bruce381
some may work some not improvement is perhaps couple percent and down side is potential harm to the oil life and perfromance of the oil.
bruce
Old Jan 16, 2009 | 09:23 PM
PatsPOS's Avatar
PatsPOS
I generally tend to follow cjben's attitude on engine oil additives...and when I saw Carroll Shelby's ad for Z-max, I thought, "Great...either Shelby is a Z-max wh0re now, or that stuff is the greatest thing since the ball-point pen...now which is it?"
All that crap that was being peddled in the '90s is just that...crap. I don't know why anything that might come down the pike in the future would be any better. But with my luck, the greatest additive for the internal combustion engine will be invented, then marketed...and I'll still be sitting there watching an ad and saying to myself, "Oh, I'll bet THAT'S a bottle of garbage!" I can't win...
Pat
Old Jan 17, 2009 | 01:26 PM
Fandini's Avatar
Fandini
Don't you think that the oil manufacturers would add it to their oil if it was that great? Kinda what I've been thinking, but when you do see someone you respect (Carol Shelby) promoting it, you want to see where that fishing lure leads you.
Old Jan 23, 2009 | 04:18 PM
rrrrick's Avatar
rrrrick
Power block and the like are just infomercials anyway. Z max has it's own great infomercial and I have treated one of the engines I run in my racecar with it. I heated up the bearings in a oven and then let them soak in the Z max. You could see a difference in color where the stuff "soaked into" the bearings, Hopefully, I won't see those bearings again until next fall when I rebuild the engine again and then I will see if the Z MAx had any effect on bearing wear
Old Jan 23, 2009 | 08:46 PM
chillmiller
but do they work as a pour in ya know? not soak and bake
Old Jan 24, 2009 | 04:50 AM
Ed's Avatar
Ed
Well the heat of an engine will "bake" the Z-Max in, Chillmiller is simply duplicating the effect in a "lab setting".
I have read that their (Z-Max) fuel treatment is very good, and it's core ingredients have been used in the aviation industry for decades in one form or another.
Airplane gasoline, with it's much high octane requirement, is much more important in having it's fuel not develop any deposits / moisture, for obvious reasons. Maybe overkill for our engines, but in the correct useage, I don't see where Z-Max fuel treatment would cause any harm in any fuel system.
Old Jan 25, 2009 | 11:37 PM
Fandini's Avatar
Fandini
Has anyone ever subjected any other light oil to the same test as they do the Z-Max. I bet any really light oil would do the same thing in similar tests, not that these test prove anything to me.
Old Jan 26, 2009 | 04:05 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just my opinion only. The only additive I know of that does work is zinc. ZDDP, GM EOS. Gov made manufactures quit using it. Even Rottella took it out. Bad for cat. converters. Brad Penn Racing oil is only one I know that still has it. It's great for cams and flat tappet lifters. The rest, like Lucas etc. will only gain you a little time in worn engines before you are forced to do repairs.
Old Jan 26, 2009 | 06:31 PM
Freaksh0w's Avatar
Freaksh0w
Oh, they still put zinc in oils. It's just that SM rated oils have less now than the previous SL rated oils. Your average SM 10W-30 dino will have 700-800 ppm of zinc. About the same for synthetic. Castrol Syntec 0W-30 is still SL rated, and it has something more like 1000 or 1200 ppm of zinc.
F-250 Super Duty
42
Feb 19, 2009 11:07 AM
heavyiron
Jan 30, 2009 12:54 AM
jim henderson
Oil & Lubrication
May 26, 2008 05:14 PM
rangersvt04
Oil & Lubrication
Apr 26, 2004 12:13 PM
