Sponsored by: Real Truck
Keyless Entry
Old Jan 6, 2009 | 05:35 PM
jump05powerstroke's Avatar
jump05powerstroke
Keyless Entry
Does anyone know how to tell if a truck has the keyless entry without having the remote. I have an 05 f-350 xlt fx4 diesel 6spd that i bought used and did not have a remote. Also does anyone know how to program the remote? Any info would be great. Thanks
Old Jan 6, 2009 | 06:09 PM
Lou Braun's Avatar
Lou Braun
Instructions for programming a remote are buried in your owner's manual. When I programmed a spare remote it was easy enough to do after about 3 tries.
You should be able to get a copy of the truck's "window sticker" if you ask a dealer. This would tell you for sure what came with the truck when it was delivered.
Lou Braun
Old Jan 6, 2009 | 06:57 PM
jump05powerstroke
Thanks, I didn't think about checking those but I will now.
Old Jan 6, 2009 | 07:45 PM
donewithsparkplugs's Avatar
donewithsparkplugs
https://www.ford-trucks.com/article/...ogramming.html
Old Jan 6, 2009 | 08:26 PM
hammer65's Avatar
hammer65
A build sheet will tell you if it has Keyless entry. Ask the parts guy "Ed" He has so nice about sending them.
Old Jan 6, 2009 | 09:28 PM
_Rick_'s Avatar
_Rick_
Hi Jump,
If you find out you need a remote here is a ebay fellow I've purchased a few remotes from in the past year or so '05 '06 '07 F250 F350 Remote. He was very helpfull and informative for me. He may even be able to offer you assistance with your question? (how to tell if a Truck has the keyless entry without having the remote) Might be worth a try if no one here can answer it for you.
ALSO:
If you know someone with a similar vehicle as yours with keyless access with a remote (many years of remotes will work) all you need to do is borrow his or her remote and follow the programming procedure on your Truck using the borrowed remote. If you get it to work then you're all set. Just reprogram it on the Truck it was borrowed from and order yourself a new remote.
THE FOLLOWING WORKS FOR MY '02 F-350. I would imagine it should be the same for your '05 but please take the time to confirm this so you don't end up waisting your time. The procedure should be available in your owners manual also.
How to reprogram your remote entry transmitters
You must have
all remote entry transmitters (maximum of four)
available before beginning this procedure.
To reprogram the remote entry
transmitters:
1. Ensure the vehicle is
electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 2 (LOCK)
position to 3 (OFF).
4. Cycle, eight times, rapidly (within
10 seconds) between the 3 (OFF)
position and 4 (ON).
Note: The
eighth turn must end in the 4 (ON) position.
5. The doors will lock, then unlock, to confirm that the programming
mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note:
If more than 20 seconds have passed you will need to start the
procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry
transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 3 (OFF) position after you have finished
programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
mode has been exited.
My Bad,,, Maybe take a look to see if there is a FTE sponsor link to order from before ebay.
Old Jan 6, 2009 | 09:56 PM
_Rick_'s Avatar
_Rick_
I didn't campare the '05 to my '02 copy word for word, but here's a copy of the '05 programming procedure just in case.
____________________________________________
You must have
all remote keyless entry keypads and remote entry
transmitters
(maximum of four) available before beginning this
procedure.
2005 F250/350/450/550
To program the keyless entry
keypads remote entry transmitters
yourself:
4. Cycle eight times rapidly (within
Note: The eighth turn must end in the 4 (ON)
position.
6. Within 20 seconds, program the keyless entry keypad by pressing the
8 and the 9 0 controls at the same time.
7. The doors will lock, then unlock, to confirm that the keypad
programming mode has been activated.
8. Within 20 seconds, program the remote entry transmitter by pressing
any button on the transmitter.
Note: If more than 20 seconds have
passed you will need to start the procedure over again.
9. The doors will again lock, then unlock, to confirm that this remote
entry transmitter has been programmed.
10. Repeat Step 8 to program each additional remote keypad or entry
transmitter.
11. Turn the ignition to the 3 (OFF) position after you have finished
seconds have passed you will need to start the procedure over again.
12. The doors will once again lock, then unlock, to confirm that the
programming mode has been exited.
Old Jan 7, 2009 | 10:50 AM
dchamberlain's Avatar
dchamberlain
You must have
transmitters
procedure.
yourself:
position.
I'm making a wild *** assumption here. But it would seem to me, that if the OP's truck didn't have the keyless entry option, that this programming procedure would not work and if he tried it and reached step 5, the doors WOULDN'T lock and unlock.
It would follow logically (maybe) then, that if his truck DID have the keyless entry option, that the programming steps would work and when he got to step 5 his doors WOULD lock and unlock.
So it seems to me that he ought to try this procedure. If he gets to step 5 and his doors lock and unlock, then he could assume that he has the keyless entry option, go and buy a remote and try it out. If they didn't, he could probably assume he does not have the option.
There would be no harm in going through the steps up to 5 to try this out.
Old Jan 7, 2009 | 01:21 PM
_Rick_'s Avatar
_Rick_
Originally Posted by dchamberlain
[/left]
Yup, That is the basic idea.
If it works he has the keyless entry package.
If it doesn't work he doesn't have the keyless entry package.
It's a pretty simple process. I've been trough it several times. It should prove to be a sure fire way to confirm if he does or does not have the keyless package in his Truck.
Rick...
edit:
I should say,,, I've been through the process several times with my '02 which does not have the key pad, but it will still get him the answer he's looking for.
Old Jan 7, 2009 | 03:16 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
a vin an a email, and I can git'r done!
Ed
Old Jan 8, 2009 | 03:59 PM
verticalrich's Avatar
verticalrich
can u get me a build sheet?
1FTNX21P24ED44138
RICHHOXEY@ ATT.NET
Old Jan 8, 2009 | 05:23 PM
FTE/PARTS-GUY
Former Vendor
1FTNX21P24ED44138
RICHHOXEY@ ATT.NET
did you get it ok?
ed
mprice
1978 - 1996 Big Bronco
Apr 30, 2010 03:38 PM
Club Wagon
1997 - 2003 F150
Nov 2, 2007 11:24 AM
JB7
22
Dec 3, 2003 09:58 PM
ghlacy
Sep 10, 2001 09:11 AM
