Power steering mod
Old Jan 6, 2009 | 12:33 PM
matty169's Avatar
matty169
Power steering mod
Anyone know what or how to modify power steering pump or box to make the truck steer easier with bigger tires? Thanks
Old Jan 6, 2009 | 12:56 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I think I remember reading here that someone put a pump in from an F-550 to help with that. I do not know (for sure) if there is a difference in the pumps but I do seem to remember reading about that.
Old Jan 6, 2009 | 01:12 PM
F350-6's Avatar
F350-6
Are you referring to adjusting the nut on the back of the steering box? If so, just do it a little at a time to see if you notice a difference.
Old Jan 6, 2009 | 02:44 PM
matty169's Avatar
matty169
Nooo
No. I need to increase the pressure from the pump in order to turn 35's at idle and low speeds.
Old Jan 6, 2009 | 02:46 PM
matty169's Avatar
matty169
Try this
powersteering Im trying this.
Old Jan 6, 2009 | 04:52 PM
mattpowerstroker's Avatar
mattpowerstroker
adjusting the nut on it what would that do
Old Jan 6, 2009 | 05:00 PM
superduty4x4's Avatar
superduty4x4
Its supposed to help remove slop from the steering box, but if you over-do it your steering box can bind (not good) or go completely TU on you (even more not good).
Old Jan 6, 2009 | 05:44 PM
smoky_diesel's Avatar
smoky_diesel
I did this on my bronco's Saginaw pump and it does work well. the box leaks faster now.
I did not see a way to shim the gen. 2 ford PS pump that are on 80s and 90s fords and PSDs.
Old Jan 8, 2009 | 04:48 AM
matty169's Avatar
matty169
Mod
Adjusting the nut only removes slop in the steering. This mod increases pressure from the pump. The hydroboost should be modded by making the fluid passages larger. As in 5/8 instead of what they are now. Allows for steering at idle and low speeds with larger tires.
Old Jan 8, 2009 | 07:23 AM
UP_There's Avatar
UP_There
You went from asking.....to telling us how to do it Nowhere in that link does it say anything about a Ford powersteering pump. Jeep's and Chevy's are the only type I saw
Old Jan 8, 2009 | 07:47 AM
03_PSD's Avatar
03_PSD
have you tried changing the PS fluid to synthetic. when i changed mine out it felt like a new pump. worth a try.
Old Jan 8, 2009 | 08:13 AM
7.3L DID TD's Avatar
7.3L DID TD
I've always be considering switching to Synthetic in mine who's did you use? Thanks
Old Jan 8, 2009 | 08:19 AM
03_PSD's Avatar
03_PSD
i went with moble 1
Old Jan 8, 2009 | 09:17 AM
redfire42's Avatar
redfire42
Do you use powersteering fluid or tranny fluid? I was always told its the same thing?
Old Jan 8, 2009 | 09:20 AM
03_PSD's Avatar
03_PSD
tranny fluid is what i used
