Over the summer I would like to add the factory fog lights to my 08 250SD... does anyone have the part numbers needed... i.e. lights, brackets, wires, headlamp switch.
Also, I have seen pictures of trucks with some additional switches next to the 4x4 switch... what are they supposed to be used for, and any one have the part number for the one with additional two switches?
The two switches next to the 4X4 switch are for Traction control and to turn off the back up sensors If you need extra switches install upfitter switches these other switches are not very heavy duty.
I would not be driving anything directly, so that doesn't concern me at all... I like that location better than where the upfitter switches are...
E-bay also has them available, some are OEM and others repro.
Your truck probably won't have the factory harness set-up for them (at least the 06 doesn't) so you will probably have to do all your own wiring.
