I changed the gear oil in both of my diffs. On the rear diff, what is the small toothed part that looks like a chain ring opposite the ring gear? It is about the same diameter as the ring gear. Also, is my rear axle a Dana 60 and front a Dana 50?
Thanks!
Maybe. The tone ring pulls double duty on the superduties. It is the VSS (vehicle speed sensor) as well as the ABS sensor. For your other truck to not have a VSS on the pumpkin, it would have to have a VSS on the transmission.
