Flamethrowers
Old Sep 10, 2003 | 10:41 PM
  #31
brown_z71's Avatar
brown_z71
Flamethrowers
that still doesnt answer our ? about getting more fumes or whatever to egnight? i also have threaded plugs i just need some flamable way that it will throw the flame!
Old Sep 11, 2003 | 09:55 AM
  #32
DrHook's Avatar
DrHook
Flamethrowers
You shouldn't get fumes if your cat's are on the truck still. That's what they do, burn any fuel/fumes that are left in the exhaust before it exits the truck. If you are getting to many fumes left over the cats begin to work to hard and start to melt down. So if your cats are gone and your truck isn't running well then you might have enough fumes to shoot flames out the pipes.
Old Sep 12, 2003 | 08:59 AM
  #33
KJKozak2's Avatar
KJKozak2
Flamethrowers
I have a rich-running 460 w/dual exhaust and ran it with full choke and still couldn't get flames. I have the electrical part installed and working prefectl, but no fire.
My next test will be to disconnect a plug wire on each side to see if that makes a difference. If not, I think it might be better for the engine to just inject something into the tail pipes.
I also agree about the EFI and cats. EFI is just so much more efficient than a norm. asp. engine that you probably wont get enough unburnt gas (even without cats).
K.
Old Sep 12, 2003 | 09:30 AM
  #34
DrHook's Avatar
DrHook
Flamethrowers
kjkozak2, I don't know what your running for an exhaust system, but I found if you run 2 1/2" front pipes and 2 1/4" tailpipes, along with some glasspack muffler you should be getting some flames when you let off the gas from a hard acceleration. 2" tailpipes would work even better but won't be enough flow for your 460. 2 1/4" is even pushing it if you have done any mods to your truck. Older Small blocks work so much better at getting some flames.
Old Sep 12, 2003 | 09:40 AM
  #35
KJKozak2's Avatar
KJKozak2
Flamethrowers
DrHook,
I agree that mine should work, but I only gave it a half-hearted effort that day due to time restraints. Hopefully, I just screwed something up and I'm not getting enough spark or something. It's really hard to look up the tail pipes and check from the driver's seat, though.
Kevin K.
Old Sep 14, 2003 | 04:12 PM
  #36
Truckmano5's Avatar
Truckmano5
Flamethrowers
When i used to have side oilers i could shoot 2 1/2ft flames out the sides with no kit. It helps to have blown out mufflers and a 4 barrell edelbrock
62vetteman
Mar 7, 2017 04:36 PM
4wdV10
Testing.....
Aug 30, 2016 09:44 PM
eagle275
May 23, 2016 11:28 PM
Joe19
New Member Introductions
Nov 14, 2014 02:22 PM
bill1751
All Things Towing
18
Dec 17, 2005 05:24 PM
