Injectors
Old Jan 5, 2009 | 08:49 PM
04F-250mark's Avatar
04F-250mark
Angry Injectors
Just wandering IF ANYBODY HAS HAD THIS HAPPEN,the other morning I got up to go to work and started my truck it let it warm up,after a few minutes it idled up as it alwasy has. But when I went to go to work I was suprised to see smoke bellowing out the exhaust pipe. IToday when I wengt to work I didn't let it warm up,and 150yrds down the road at a red light I noticed smoke (wind was in right direction ).IT looked black or gery "it was 5:30 am !! Then after about 3/4 mile it was gone. I talked to the dealer who studded it and they said it could be an INJECTOR possibly they wanted me to bring it in.Thats when I informed them I was about 600miles away. They told me to take it to a dealership here in mississippi.ANY IDEAS or has this happened to anybody else?? THANKS FOR ALL THE INPUT!! , THIS iS ME NOW !!
Old Jan 5, 2009 | 11:15 PM
TreeTech's Avatar
TreeTech
If it is blowing White Smoke or Steam your egr cooler could be bad.. If it is black/greyish smoke you could have injector of vgt issues..
Old Jan 6, 2009 | 07:02 AM
tex25025's Avatar
tex25025
Was it blowing smoke at idle when you got to work? If it is continueing blowing smoke at idle(or atleast your able to see it at idle), then there is a good chance that you have a leaking injector. Do you smell unburned fuel?
Old Jan 6, 2009 | 05:06 PM
06silvercrew's Avatar
06silvercrew
Smell the exhaust and see if you can smell fuel, if its bad enough it will burn your eyes out lol Def. sounds like you have an injector or two hanging open. How did the truck run when first started cold?
Old Jan 6, 2009 | 06:33 PM
04F-250mark
I went outside to look at it this morning with a flash light.It didn't smoke right after start-up it took about twoo min. then I stsrted to see it. I took a big whiff and I could smell fuel in it and it was greyish/black I guess. gonna look at it in the morning with a bigger flashlight. Talked to a dealer today they said to bring it in in after work and leave it.back when we had a 10deg mornings it started rough and missed for about a min or two .The other day is when I noticed it to begin with. Another question is why will the idle jump up from 650RPM to almost 900RPM after a min or two???
Old Jan 6, 2009 | 06:40 PM
juneau76's Avatar
juneau76
Do you mean when you first start it up and it sits for a minute? Based on ambient temp, the engine idles up to warm the engine. Mine idles down once it hits the "magic engine temp". I really need to do the high idle mod...
tex25025's Avatar
tex25025
If it happened on cold mornings then it could be the factory idle up that is programmed in the computer.
ten.mile
May 16, 2020 04:34 PM
cbr600rx7
47
Jan 30, 2013 05:48 PM
ten.mile
Dec 11, 2012 05:56 PM
triggernut7788
36
Oct 12, 2011 08:39 AM
Technocrsr
Jun 6, 2007 08:27 PM
