nuthin' but buzzin'
Old Jan 5, 2009 | 05:26 PM
stevesc's Avatar
stevesc
nuthin' but buzzin'
Hopefully y'all can help me w/ this...(90 E350 4.9)
First, when I was on the road today, my van would not start at one point.
When I turned the key I got dash lights and buzzer, but nothing else.
I finally got it started my messing w/ shift lever. When I got home it happened again in my driveway (how convienent), but this time I couldn't get it to start. I replaced the neutral safety switch and got no change. The new swith doesn't have an alignment hole like the original so I am not really positive that it is not still the problem, but I messed w/ it for long enough that I am reasonably sure it is not the culprit. I even sacrificed the old one to use as a bypass and still couldn't get anything.
The ignition switch is new (that causes odd problems when it starts to fail), so I doubt it is that.
I used jumper cables to jump the starter solenoid and got nothing!!!
Does that mean the starter is bad?
Shouldn't I hear something if that was the case?
Thanks for any assistance..
Old Jan 6, 2009 | 11:46 AM
bjafeman's Avatar
bjafeman
It's not entirely unheard of for a starter to get really hot and melt a wire. Check the cables coming from the starter, including ground(s). If you're applying direct current to the starter AND the ground is connected, then that points (pretty much directly) to a bad starter. Work backward from there
Old Jan 8, 2009 | 07:29 PM
stevesc's Avatar
stevesc
Solved
Thanks, it turned out to be both the starter and the solenoid.
Now it starts like new and with authority.
Old Jan 8, 2009 | 08:12 PM
Harte3's Avatar
Harte3
My starter just went kapoot today. Just ordered a mini unit off eBay. Time to switch cables while I'm at it too.
JoeSwing78
34
Aug 23, 2013 05:53 PM
chappys4life
Jun 29, 2012 12:05 AM
fakirone
Jan 6, 2011 01:40 PM
fakirone
Electrical Systems/Wiring
Jul 27, 2010 02:22 PM
wahunka
Feb 13, 2006 08:37 PM
