Sponsored by: Real Truck
E250 Starter problems
Old Feb 13, 2006 | 05:27 PM
wahunka's Avatar
wahunka
Cool E250 Starter problems
Here's the story: We got some major snow over the weekend. My wife went to start my truck which is a 2003 Ford E250 Van. She used a key that is my last ditch spare. The key works in the ignition, but if you use it and don't pay attention, the key stays in the START position. When I went out to start my truck this morning, it wouldn't turn over. I thought it was the battery but it is not.
I started looking and reading. I replaced the starter relay on the side near the battery and still nothing. My next guess is the starter. Could she have burned it out, but it getting stuck in the START position? Could she have damaged more then just the starter? I am going to take the starter out in the morning and see what it does.
I couldn't find any fuse that might be involved and the fuseable links to the starter relay appear to be good but i didn't test them.
This looks to be a great forum. Thanks,
Lewis
Old Feb 13, 2006 | 05:29 PM
Beast12's Avatar
Beast12
Welcome to FordTrucks.com! We are the Internet's Premiere Resource for all things Ford Truck and SUV related!
We are happy to have you! There is a ton of great info on this site. But, before you go snooping around there are a few things you need to do first.
1) Want to meet or talk to other members in your area? There are Provincial, State and International Chapters located near the bottom of the main forum page.
2) Before you post a thread asking a question be especially aware of where (what forum) to place it in. FTE is HUGE! Make sure you read the Read First: at the top of the forum before you go posting.
3) And finally you should review the Guidelines. They will kind of give you an idea of what is and isn't allowed on this site ("The Rules").
And that is it. I hope you enjoy the FTE "Experience"! This is a great place and we have lots of fun while exchanging valuable info. If you have any questions or problems do NOT hesitate to contact me. Just click my username then send me an email.
-Matt
Old Feb 13, 2006 | 07:56 PM
99f350sd's Avatar
99f350sd
Sounds like the starter got toasted maybe. You need to get a test light and stop guessing. Its easy to walk you through how to test the system.
Dick
Old Feb 13, 2006 | 08:25 PM
wahunka's Avatar
wahunka
I'm going to get out under the truck on Tuesday. We got 15 inches of snow so its not easy to do and its cold. I will check for voltage at the starter. What I can do is turn the key and check by myself. I hate to get a new starter if that isnt the problem but i couldn't think of anything else. I am almost 100% sure it was stuck in the Start position. My wife also said she didnt hear the defroster running. my guess was the engine was running and the key was stuck and nothing else worked. It looks pretty easy to remove the starter, just need to keep track of what wires go where. the one on my motorhome was easier, more room to work. I'd check the solenoid first when i got it out and see if the starter moves. if it does, then i have to figure out what else might have been damaged.
Old Feb 13, 2006 | 08:37 PM
99f350sd's Avatar
99f350sd
The solenoid on the fender well should click when you turn the key to start. There's two small wires on the solenoid one comes from the sw and the other goes to the starter. They both should be hot with the key to start pos.
Dick
Csilcox
2009 - 2014 F150
Feb 25, 2017 10:05 AM
taylerallen6
1997 - 2003 F150
Jun 21, 2016 06:45 PM
Singing River Farm
18
Jan 25, 2014 03:51 PM
BrandonT71
Aug 2, 2013 07:52 PM
E30tdf
Apr 7, 2012 09:49 PM
