Sponsored by: Auxito
How Long Before Plug Change
Old Jan 5, 2009 | 04:45 PM
boatnfish's Avatar
boatnfish
Curious as to how long (years & miles) people have gone before changing plugs on a 5.4.
Why did you eventually change them, and what problems did you have?
Old Jan 5, 2009 | 05:04 PM
n5926g's Avatar
n5926g
Under normal circumstances,Id say replace the plugs/wires at around 100,000 miles.Ive never personally had one go bad on my 97 4.2,but after the 100K mark,the gap will be eroded enough to at least require re-gapping.The wires are pretty much a no-brainer,as most wires will come apart when the plugs are changed.
Concerning time,id say(if youre engine stays relatively clean) 4-5 years on the wires.
I remember my 70 Mustang with the 302 required plugs about every 5000 miles or so,but THAT was a carberated engine.Todays fuel injected engines make plug changes almost non-existant.
Old Jan 5, 2009 | 05:08 PM
LxMan1's Avatar
LxMan1
I changed mine @ 70K and they were worn, but not real bad.
Old Jan 5, 2009 | 06:29 PM
galaxie641's Avatar
galaxie641
60K-70K. They are too easily screwed up and made to blow out if you leave them in too long and/or do not torque them properly. The ignition systems run so hot that it doesn't take much of a plug to fire the cylinder so it really comes down to replacing them as preventative maintenance for the blow out. Make sure to replace all the COP boots since you will be in there anyway.
Old Jan 5, 2009 | 10:16 PM
steve(ill)'s Avatar
steve(ill)
i bought my F150 with 120k miles. Had a miss by 130k miles. Changed out all the plugs. all were original and WIDE gaps. Book says 100k intervals, that sounds like a good point to me.
Old Jan 6, 2009 | 07:13 AM
mjunk1's Avatar
mjunk1
I'm thinking around 100k as the book says also. Wouldn't hurt to go a bit early, probably wouldn't hurt to be a bit late. If they are bad, you'll know it by the way it runs.
Old Jan 6, 2009 | 02:09 PM
tj90's Avatar
tj90
I changed mine at 100k and it was a mother getting them out from all the years of dirt and crud. Antifreeze crusted down the holes doesnt help either. I will replace at 50k intervals from now on, just to make the replacement easier on me in the future!
Old Jan 7, 2009 | 01:46 AM
geoaigel's Avatar
geoaigel
I had the wires go bad before the plugs. 60k on my 4.6. I would change the plugs around 60k.
George
Old Jan 7, 2009 | 02:16 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
My '97 4.6L started mis-firing at 102,000mi. I would change them every 80k...
Old Jan 7, 2009 | 04:31 PM
boatnfish's Avatar
boatnfish
Well, I am over 150k. Probably just leave them alone at this point in history.
Old Jan 9, 2009 | 12:30 PM
96f150's Avatar
96f150
I'm looking at 95k and still running fine, I'm gonna keep my fingers crosssed!! I think I will attempt the feat in the spring though.
Rich
Old Jan 9, 2009 | 01:38 PM
sierrafour's Avatar
sierrafour
114K on mine now. I will probably do them this summer though just to be safe.
FUJINAMI1293
27
Jan 21, 2013 10:58 PM
G5.4
Apr 28, 2011 11:07 PM
wameyer
16
Jan 30, 2011 09:46 PM
MWH615
Mar 2, 2010 11:32 AM
00Dave
Dec 30, 2007 06:25 PM
