Drive shaft components...
Old Jan 5, 2009 | 11:46 AM
dave boley's Avatar
dave boley
Hi Folks,
Before I spend what may turn out to be a waste of time, I thought I'd post this to see if anyone knows a link or source.
Twenty+ years ago when we lived out in the country I used to build a lot of one of a kind stuff and I made quite a few drive shafts. At that time the local independant parts store had a Spicer catolog that listed all the various drive shaft components by specs of size as opposed to listing by application. Since that time that place and it's parent parts warehousing company have been bought up by some Canadian conglomerant. I suppose they have made certain changes to try and compete with the likes of Auto-Zone and in that process they have decided that this sort of catalog listing system is no longer of any value to them.
Recently when I was in the place I asked if they still had those type of listing catalogs for Spicer and I got that typical deer in the headlights look from computer driven parts droid behind the counter followed by the usual question about what vehicle is it for. When I tried to explain, it caused an instant system crash for them droid.
I can't believe Spicer dose not publish this type of catalog. I was wondering if anyone here has any knowledge of a link or source to this sort of listing. Eventually I will attempt some sort of search but a heads up from someone that has already done this would be a real time saver. Possibly there is something online in a PDF format.
Thanks in advance to anyone that might be able to help with this.
Later Folks...
Old Jan 5, 2009 | 12:42 PM
mcdonaldm's Avatar
mcdonaldm
check the dana spicer website, they should have the cat you are looking for.
also check with your local 4 x 4 shops, they should or will know what you are looking for as they make custom driveshafts all the time.
also check your local yellow pages for driveline repair shops. there are 2 or 3 here in Edmonton that specialize in custom driveshafts mostly for semis and construction equipment but they also do car driveshafts (had mine shortened by one of the local shops).
also if that fails, try a place called Allpower Transmission out of Green Bay WI. very good company to deal with and cheap. buy lots of custom driveshafts for standby pumps for work from them. even with shipping and difference in dollars, they are still way cheaper than local companies.
rgds
Mike
Old Jan 5, 2009 | 04:55 PM
dave boley's Avatar
dave boley
rgds
Mike
Thanks Mike,
I did plan on checking their site but I thought I would check here just in case someone already had the URL. I'll check those other places. I want to do my own work because I have a machine and welding shop here. No sense in paying sombody else to do what I can do myself.
Later Man...
Old Jan 5, 2009 | 05:33 PM
4tl8ford's Avatar
4tl8ford
Also check with Truck repair places.
If you can't find what you're looking for let me know. I have a couple of local shops here in town that can fix you up.
google "Erie Drive Train"
Old Jan 5, 2009 | 05:41 PM
55 f350's Avatar
55 f350
if i can't find it online in someone like dana's site , i call up a local heavy truck parts / repair place called ACME over in decatur . they have all the catalogs etc. you could ever want , and made the driveshafts for the 53 when i went to a two peice . had to get one of those odd u joints too , and they were cheaper than the 1 parts house out of a million here it seems , to get it . bigger on one side smaller on the other .
Old Jan 5, 2009 | 07:32 PM
dave boley's Avatar
dave boley
Thanks to everyone...
Later...
Old Jan 5, 2009 | 08:00 PM
dave boley's Avatar
dave boley
Found it >>>
Thanks Guys. I found what I was looking for, CLICK HERE. Once I have the right PN I can go for the best prices.
Later...
creator
Apr 24, 2023 04:01 PM
RoadTractor
Sep 11, 2019 11:51 AM
carguy3j
16
Feb 21, 2016 08:48 AM
psi4pwr91
Dec 24, 2015 07:37 AM
housedad
May 30, 2014 12:23 PM
