fuel help
Old Jan 4, 2009 | 05:24 PM
hanklin's Avatar
hanklin
fuel help
I start my truck and fuel is gushing out of valley on motor. I think it`s behind fuel filter, theres a little yellow thing that moves around if you touch it. I moved it about (spun) 90 degrees and fuel was pouring out again.What the heck is it? Do you think I can drive about 3 miles to repair the prob?Need some help here
Hanklin
Old Jan 4, 2009 | 05:26 PM
krejci.mike's Avatar
krejci.mike
just twist it back. its the housing for the fuel filter. the lever is to get the water out of your fuel
Old Jan 4, 2009 | 05:27 PM
fxstbchopper's Avatar
fxstbchopper
That is the fuel bowl drain valve the o-rings are probably shot.
Edit: If you are only going about 3 miles you should be fine. Keep an eye on it though.
Old Jan 4, 2009 | 05:39 PM
DND58's Avatar
DND58
Click here for a repair write up, courtesy of Guzzle.
Welcome to guzzle's PSD Fuel Filter Drain Valve Repair Web Page
DND58
Old Jan 4, 2009 | 07:00 PM
hanklin's Avatar
hanklin
Bingo,nailed it with the o-rings.
Thanks much for help ,I`m gonna order an extra set in case it happens again
Hanklin
Old Jan 4, 2009 | 07:32 PM
Steve_250's Avatar
Steve_250
Hank?
Have you not drained it in the past? Replaced the fuel filter?
I just thought it an odd question from someone with all the listed mods and 400+ posts...
But then again, some ppl purchased used with mods already done.
Well, at least you've drained the fuel bowl recently, LOL!
Get some Simple Green or Purple Power and clean up the valley.
Old Jan 4, 2009 | 07:35 PM
hanklin's Avatar
hanklin
No I haven`t . I have best friend who is my mechanic and he always takes care of filters/oil changes,etc.
I plead ignorance on this one
Hanklin
Old Jan 4, 2009 | 08:21 PM
krejci.mike
sorry I miss understood you I thought you had just left the lever open....
