Finally, maybe progress: Code 0470.....
Old Jan 4, 2009 | 02:01 PM
jyblood's Avatar
jyblood
Been have intermittant problems: 1)Either the truck misses at idle or 2)the truck idles fine but runs with low MPG/Power, or 3)no problems at all. Finally it throw a code 0470 Exhaust Back Pressure Sensor Circuit Error. At this point, being new to things mechanical/PSD, I need some direction.
Thx's, Fred ( jyblood@nwi.net ).
Old Jan 4, 2009 | 02:11 PM
gunnertom's Avatar
gunnertom
I'am not the best at this but here it goes,The sensor is in front of the hpop.The tube from the right side exhaust manafold is probably clogged that goes to the sensor
Old Jan 4, 2009 | 02:15 PM
gunnertom's Avatar
gunnertom
remove the sencer an run a weed eater string down the tube ,an check for pin holes in the tube.
Old Jan 4, 2009 | 02:32 PM
rbaker6336's Avatar
rbaker6336
the 0470 code shouldn't affect the way your truck runs but some say will affect fuel milage
Old Jan 4, 2009 | 07:10 PM
F350-6's Avatar
F350-6
Here's a link on how to clean the tube mentioned Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
When it's cold outside and the engine is cold, will the truck increase idle on it's own after a minute or so?
Old Jan 5, 2009 | 05:28 PM
hndamxmn's Avatar
hndamxmn
I was getting the same code followed the link they gave you on this thread. I only took my sensor off and cleaned it really good and made sure I got all of the black build up out of the bottom side of the sensor and put it back together. I got lucky and the 470 code is gone. the link is really helpful when followed step by step. Good luck!!
Old Jan 5, 2009 | 05:30 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Good job, makes these hours spent here worth it when someone fixes it.
