exhaust
Old Oct 17, 1999 | 02:23 AM
Huke's Avatar
Huke
exhaust
Old Oct 23, 1999 | 02:20 PM
nissanjon's Avatar
nissanjon
exhaust
truck:87 f150,302, AOD
right now the truck has dual tips after the muffler. would there be any benefit to switching to a fat single exhaust pipe? i've heard that if you have too much exhaust flow, you lose low end torque. would i notice an improvement off the line, or anything, if i made the switch?
Old Oct 24, 1999 | 08:11 PM
charles_1's Avatar
charles_1
exhaust
No, you woudnt notice anything. I would leave it like it is. The less backpressure the better.
Old Oct 26, 1999 | 02:58 PM
curly's Avatar
curly
exhaust
You will lose low end driveability with too little backpressure in an otherwise stock truck. In this case, however, the backpressure in your exhaust is taken care of by the convertors and the muffler. A muffler-back change probably won't do much of anything. A converter back change (to a free flowing exhaust) may not even change much. Something like straight duals, no cats, and hi-flow mufflers would hurt low end but give you more top end power.(not much use in a truck)Be sure to use an H-pipe or you will really kill the lower R's.(if you do choose duals)
Old Oct 26, 1999 | 03:05 PM
Pastmaster's Avatar
Pastmaster
exhaust
>choose duals)
Funny, I have duals after the convertor w/o mufflers and stock convertor, and I could tell a big difference in both low-end torque and slower high-end torque. Then I decided to put on Headers and eliminated slow high end!
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Oct 27, 1999 | 10:42 AM
curly's Avatar
curly
exhaust
In general though, lower backpressure means more power, but you can go overboard.
