My cluster was really dim when I first got my truck. I pulled the cluster out and cleaned it well. Clean all the connections on the circuit board and make sure there is no corrosion. Mine had some so I lightly sanded with 600 grit, but be very careful when doing this that you don't sand thru the board.
Also, pull the headlight ****. Mine was all gummed up from 30+ years. Replaced with a new one and put in new lights in the gauges, they shine bright and clear. But while you have it apart clean all the electrical connections and use dielectrode grease when putting it back together to stop the corrosion from coming back.
Also, when cleaning the gauges don't use Windex. I learned the hard way that it takes the lettering off the gauges. But a little white paint pen and they all look good as new.
Green Sales Co. in Cincinnati OH has 8 = 800-543-4959
Dennis Carpenter in Concord NC has 305 = 704-786-8139
------------------------------------------------------- E1PZ10848B .. Cluster Back / Use with Amp and Oil Pressure (Idiot) Lights / Obsolete
Instrument cluster lights, etc. very dim. Some lights not working. Where could I get a new cluster board and How hard is it to fix?
While I'm here, need new interior door panels[black], floor pan[drivers side] !
First time on forum, thanks
Paul
I had the same problem with my 79 i bought a used one on ebay that was in excellnt cond for $50.00 and it fixed my problem
Aside from the maintenance tips that you've been getting here (new bulbs, clean the contacts, remove covers, etc.), there is another potential improvement to be made on our instrument clusters.
I've been tearing my office apart at home trying to find the contact information for a place here in Tacoma, WA that will take your instrument cluster, and retrofit it with LED's for more ambient background light. They can use a pale green LED like the lights look in our clusters, but it will be a LOT brighter.
As soon as I can find those notes, I'll post the info. I plan on having mine done before I put the cluster back in the truck...but I also plan on completely rebuilding the cluster too. I already have all the parts, just have to do it.
Thanks guys.
As I was driving the ford today I got to thinkn' about some of the info I have rec'ed here and a question came up........
Are we looking at a 3 pc deal?
From the front looking at it we have the dash part with clear plastic lens
Then the actual gauges
Then the board with that the lights twist into
or am I thinking more then I should.
Sorry I'm asking so many ? but just want to do the right thing here before I pull the dash apart to order stuff.
Also need to find interior door panels in black with padded arm rest.
If you were to put a new carb on a 351m, what kind would you get?
Thanks again and always
Paul
Thanks guys.
Paul
I would get a Holley or Edelbrock 600-650cfm carb with vacuum secondaries.
BTW, it is usually a good idea when asking a new question to start a new thread and give it a descriptive title like "Best carb for a 351m."
Thanks guys.
The instrument cluster consists of the lens (with the associated plastic down to the gauges. The gauges are attached to the plastic cluster back (where the lights are screwed in from the back). The printed circuit board is on the outside of the cluster back (the lights go through the appropriate holes in the cirsuit board and are screwed into the cluster back).
When you take it apart, the instrument cluster will essentially be in two parts - the lens and plastic assembly then the cluster back with gauges, lights and printed circuit board.
It's was not a plastic cluster back originally.
The plastic cluster back is a Ford replacement from a 1981/91 Econoline (gauges) or 1981/86 Econoline (idiot lights).
I know it wasn't plastic originally. I was just trying to explain what he would have when disassembling the cluster in reference to his question in post 23. Threw plastic in there thinking about what I now have in my 77.
BTW, what was the original material construction of the cluster back? Just curious as I went through the disintegration scenario on mine.
if it hasnt been mentioned before clean up the contacts on the circut board with fine steel wool. add a second ground to the metal bonot sure what its called) on the back of the circut board
