Black Smoke
Old Jan 4, 2009 | 12:02 AM
CarolinaMafia's Avatar
CarolinaMafia
Black Smoke
How Can I Get More Smoke To Dump On My 96 I Got A Ts Chip On There Now But It Doesnt Dump Enough Is There A Cheap Way To Make It Blow More
Old Jan 4, 2009 | 12:20 AM
Gobstopper909's Avatar
Gobstopper909
10k mod, walmart bag over your air cleaner,an oily cocktail dumped down your stacks. if you have stock injectors theres only so much any chip will give you. upgrading to a custom burnt chip will yeild a little more but not much.
Old Jan 4, 2009 | 12:26 AM
JethroF250's Avatar
JethroF250
the oil cocktail works i tried it lol. but the burnt oil smell and continuous smoke is a little much when the truck aint even runnin as you walk into McDonalds
Old Jan 4, 2009 | 04:47 PM
slwsmkn444's Avatar
slwsmkn444
I like your thinkin
I was just wondering the same thing as i got blown off the road by a 5.9 this morning!! what cheap home remedies are there to roll a little coal out the powerstrokes?
Brad
96 7.3 SC LB 4x4 Edge Evolution, AFE Stage 2, 140v IDM, 3"dp 4" straight pipe, FPR shim, Train Horn
Old Jan 4, 2009 | 05:19 PM
Brown Falcon's Avatar
Brown Falcon
what's the 10k mod?
Old Jan 4, 2009 | 05:38 PM
Gobstopper909
its where you add a resistor inline to your icp sensor (injection control pressure). the mod raises oil pressure telling the pcm to give more fuel. a littke more smoke with stock injects, also rougher idle
Old Jan 4, 2009 | 05:46 PM
slwsmkn444's Avatar
slwsmkn444
Yeah but I thought I read somewhere that it is pointless to do the ICP mod or the Oil Temp Mod if you already have a chip because the chip already fools the PCM. Is this true does anyone know or have both done with a chip?
Brad
96 4x4 SC LB E4OD, AFE Stage 2, Edge Evolution, 140v IDM, FPR Shimmed, 3"dp 4" straight pipe, Train Horn, 33's BFG's
Old Jan 4, 2009 | 10:25 PM
Gobstopper909
custom burnt chip= dont waste your time with EOT, 10K
tuner= you will see a difference in smoke/power...how much will depend on the truck
i could be wrong...BUT before my tw chip, i used a superchip for the longest time with my stage 1 sticks. i tried the 14.7K resistor and it gave me more power.
now with the tw, it just throws a cel a heck of a lot sooner in my higher settings
stickittoem
General Diesel Discussion
42
Mar 5, 2008 03:20 AM
mudracin74
21
Jan 21, 2007 11:33 PM
fishfanatic
Oct 22, 2005 03:25 PM
southernfordman
General Automotive Discussion
Sep 27, 2004 06:53 PM
