Sponsored by: Real Truck
best place to hook
Old Jan 3, 2009 | 06:16 PM
kelly67's Avatar
kelly67
best place to hook
Is it a safe bet to hook to the hitch? I have a receiver with a clevis in it that I use to hook the chain or strap. I thought of tow hooks but not sure how much they can handle.
I use to hook to the front tow hook on my toy but noticed years later that I did tweak it where it connected.
I don't jerk hard when pulling anyone out!
I do use the hitch to tow a camper in the summer 4,00lbs
Old Jan 3, 2009 | 06:33 PM
WeWonIt's Avatar
WeWonIt
I used to pull people out all the time with my tow hitch on my old 86 mud toy I had. It seems the safest load bearing place on the vehicle. When using the front hooks, I use a towing bridle shackled to both hooks and pull with both. I have used this bridle method to pull 80' fishing vessels in heavy seas, I assume it'll work on a truck. Some of the cleats on those boats couldn't have been as strong as the hooks on my truck.
Old Jan 3, 2009 | 06:45 PM
shorebird's Avatar
shorebird
A class iv HD receiver hitch is only rated to 10k# pulling weight. A tow hook on the front of the F-150 is rated to 125% of the GVWR.
Old Jan 3, 2009 | 06:55 PM
kelly67's Avatar
kelly67
OK so I'll get a bridal hook and try an pull from the front as much as I can.
This spring I'm installing a front mounted hitch to move things around. the bumper and hooks have to come off but will go back on when done.
Old Jan 3, 2009 | 09:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The most important thing is to have big enough shackles and strong enough straps. Don't get wussy hardware.
Old Jan 3, 2009 | 09:20 PM
99f350sd's Avatar
99f350sd
Don't use straps with hooks on the ends they act like bungies and if they slip off either vehicle the metal hook will find you through the windshield....Ask me how I know! Happened 17 years ago. I try to use the strap without the hooks and use a clevis that can't come off the trucks...Oh the front hooks are best,unless you have a rear bumper with front hooks in it like I do. 6x8 box 1/4 wall w built in hitch. Way stronger than the truck frame...
Dick
Old Jan 4, 2009 | 11:20 AM
WeWonIt's Avatar
WeWonIt
The tow bridle I used was spliced with 2 3/4" double braided nylon line with shackles at the frame only. Always be sure you secure the straps, chain, or whatever you are using so as to not have the problem 99f350SD was talking about. I dont use hardware to connect the lines, I use a bowline knot.
I'm kinda nautical that way.
Old Jan 4, 2009 | 11:27 AM
hanklin's Avatar
hanklin
best place to hook
Man I thought this was illegal in most parts
they might impound your truck
Hanklin
Old Jan 4, 2009 | 11:57 AM
WeWonIt's Avatar
WeWonIt
Originally Posted by hanklin
best place to hook
Hanklin
No, you must be thinking of the "Bridal" hook.
That kind of sounds fun too, I'm going to go get some smaller hardware
Old Jan 4, 2009 | 05:01 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I've used the receiver hitch for pulling stumps in 4LOW with all four wheels hopping, and then backing up and taking a run at it - enough to break a 5/8" change. The receiver pin still looks brand-new.
