Draining HFCM on 6.0 Excursion
Old Jan 3, 2009 | 04:06 PM
brooklyn born's Avatar
brooklyn born
Question Draining HFCM on 6.0 Excursion
Guys i need some help. ive been underneath my Ex. 3x with the powerstroke manual. according to the pic. there is a lever that you rotate outwards to drain the water. i know what i'm looking at and see no lever. whats up?
Old Jan 3, 2009 | 04:10 PM
bismic's Avatar
bismic
On the lower area of the HFCM - Do you see a brass plug with a hex head (6 mm allen wrench fits into the head)?
Old Jan 3, 2009 | 04:24 PM
brooklyn born
yes, that i see. is that the drain ? is the ford manual wrong about a lever? thanks
Old Jan 3, 2009 | 05:12 PM
bismic's Avatar
bismic
I seem to recall that maybe the early econoline's had a drain lever - but I do not know for sure. The plug is your drain - you will get messy when you use it. When you tighten it nack up - DO NOT over-tighten it. the o-ring does the sealing. You can strip it out.
FYI - there is an aftermarket plug that makes things a lot easier:
<TABLE style="WIDTH: 395pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=527 border=0 x:str><COLGROUP><COL style="WIDTH: 395pt; mso-width-source: userset; mso-width-alt: 19273" width=527><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl25 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 395pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: yellow" width=527 height=17>Improved Fuel Filter (HFCM) drain plug</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 395pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: yellow" width=527 height=17>http://www.forddoctorsdts.com/articles/article-05-19.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD class=xl26 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 395pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: yellow" width=527 height=17>Optional fuel filter drain plug Ford #6E7Z-9C082-A or International #2589259C91</TD></TR></TBODY></TABLE>
