Edelbrock linkage?
Old Jan 3, 2009 | 11:00 AM
alconk's Avatar
alconk
Edelbrock linkage?
Does anyone have a 1406 Edelbrock carb on a 302 with a auto trans? I have been having trouble finding a good spot for the return spring. It binds up and the throttle sticks or first thing in the morning when I hit the gas it will stick. Right now I have the return spring going to a bracket to the front of the intake. I would love to see pictures on how you have your hooked up. Thanks!
Old Jan 5, 2009 | 11:49 AM
zak8tac's Avatar
zak8tac
Just a suggestion for you, I had one of those on my chevy 350, I used a bracket that was on the back of the intake manifold (trans side) and put the spring there. Maybe you could make a bracket in the same place and try that, I never had any problems.
Old Jan 5, 2009 | 01:17 PM
78ford351m's Avatar
78ford351m
I think summit sells a kit. When I went from EFI to carb, I just bent the throttle body bracket and took the end of the spring and screwed it down to the intake. Probably not the best way, but it worked perfect.
Old Jan 5, 2009 | 08:45 PM
alconk's Avatar
alconk
Thanks, I'm at work now so I'm going to make my own bracket.
Old Jan 6, 2009 | 12:19 AM
projectbad78's Avatar
projectbad78
heres an old pic of mine.......if i can remember right, the front spring hooks around water temp sensor.....for safety, you want 2 springs.....this is a 351w/ c4
Old Jan 6, 2009 | 09:05 AM
alconk's Avatar
alconk
AWESOME!!! That's what I needed.. Thanks!!!
Old Jan 6, 2009 | 09:32 AM
78ford351m's Avatar
78ford351m
That looks almost stock. Nice work.
Old Jan 6, 2009 | 09:56 AM
myv-879's Avatar
myv-879
is the edelbrock similar to a Carter carb? the one in bad78's photo just looks like an old carter 625 I used to have (great carb IMO)
Old Jan 6, 2009 | 10:18 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The Edelbrock is a carryover from the old Carter AFB. Awesome "set it and then forget it" carburators.
Josh
Old Jan 6, 2009 | 12:52 PM
projectbad78
when i 1st got my truck the only linkage i had was a piece of coathanger.....this is where i got my linkage idea from.....
FORDMUSCLE webmagazine: Make Your Own Custom Throttle Linkage
Old Jan 6, 2009 | 07:21 PM
myv-879's Avatar
myv-879
Thanks Bullitt, it was an awesum carb, i replaced a 2 barrel holley with a 4 barrel Carter and improved HP MPG and reliability.
Old Jan 6, 2009 | 08:02 PM
alconk's Avatar
alconk
I was going to ask you what did you do for the kickdown arm on the tranny. I don't see it in the picture but you have a C4 so what did you do about that?? Looks factory indeed!
Old Jan 7, 2009 | 12:10 AM
projectbad78
when i got it, it didnt have one...ive gotten a couple from salvage yards but not one that will work right......i think im gonna go with a lokar cable.......any pics of the stock kickdown to carb linkage anyone?
