ok i give!!!!! i got my new lights. i just can't see how to get the old ones out, maybe i need a hammer . the plastic chrome trim ring is the problem i have the two screws out on top but what hold the bottom? thanks tom
there are 2 11mm(?) nuts on the back at behind the turn signal.....they will be real easy to spot if you pull the batts......but you can get to them with out pulling them,but it is a tight fit
I have the grill insert that is pictured.. I would get the part # for you but the box is in the attic, they are made by Lund and I bought mine at JCWhitney... hope that helps..
the inserts are lund thats all i know i was doing some work for a guy he went in his shed and came out with and stuck them in and i never took them out
pat
Thanks Pat...I will check it out
Originally Posted by JethroF250
not to hi-jack but where can i get the headlights? i want clear ones
