I'm replacing the front wheel bearings/hubs on my 99 F250 4wd and the new one did not come witht the 4 studs that are used to mount it to the knuckle(NOT THE WHEEL STUDS, THE 4 MOUNTING STUDS).
I tried to remove the old studs from the hub and they dont want to come wout with locking pliers and I also tried the 2 nut trick and the studs dont wanna come out.
Same here after doing 2 sets on luckly at least souther trucks they came out with a little heat. But when I battled my current truck that didnt happen. Go to ford they are like 9 bucks total.
I can change a wheel bearing in under 20 minutes now!
