white smoke
Old Jan 3, 2009 | 08:29 AM
rolltide3006's Avatar
rolltide3006
white smoke
I've got a 96 7.3 and when I start her up it is almost like I've set off a white smoke grenade in the neighborhood- I mean tons. I don't know what the prob is. The guy I bought the truck from said that he replaced the injectors. I don't know if is a fuel or oil thing. What do y'all think?
Old Jan 3, 2009 | 08:51 AM
BlueMule's Avatar
BlueMule
It just does it when it's cold right? That's normal, it's just because the cylinders aren't up to operating temperature and igniting the fuel completely.
Old Jan 3, 2009 | 09:22 AM
rolltide3006
It seems like it does it all the time. Oh well, hopefully it is a weather thing. It just seems like too much smoke to just be a cold weather prob.
Old Jan 3, 2009 | 09:44 AM
tjbeggs's Avatar
tjbeggs
Does it start up smooth? Could be some Glow plugs out. Some white smoke is normal but you could also have some GP's that aren't quite right.
Old Jan 3, 2009 | 10:19 AM
Eric_F250's Avatar
Eric_F250
from the SteveBAZ tips page...
White smoke:
Caused by unburned fuel passing through the engine. Some white smoke is normal on cold start-ups. Excessive white smoke could be an indication of inoperative glow plugs, loose injectors, low compression from worn rings or bent connecting rods, or coolant leak into the cylinders--head gasket or injector well sleeves.
Black smoke:
Caused by excessive fuel for the amount of air drawn into the cylinders. Some black smoke on hard accelerate or at higher altitudes is normal. Excessive black smoke could result from restricted intake or exhaust, inoperative leaking or weak turbo, intake hose(s) leaks, leaking or worn injectors, fuel return or supply restriction, stuck Exhaust Back Pressure Regulator valve or solenoid. Also PCM inputs such as BARO MAP ICP or EBP sensors.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods. Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.
Old Jan 4, 2009 | 08:00 PM
mcdavidson's Avatar
mcdavidson
1st, how cold is it there?
2nd, how well does she fire up? Do you have to crank several times or for a long period of time to start up?
Yes, there is relevancy here....
Old Jan 6, 2009 | 02:41 PM
rolltide3006
Thanks guys for the replies.... I got busy over these last couple of days.
