Tire Wear
Old Jan 3, 2009 | 06:36 AM
vans's Avatar
vans
Tire Wear
My 02 with 106,000 miles is showing pretty good inside wear on front tires.
Question??
I think it may be time for ball joints, if I find out it is ball joints what else should I look at replacing/upgrading while I have front end apart.
and yes I do have a budget
Thanks
Old Jan 3, 2009 | 07:00 AM
SGnAZ's Avatar
SGnAZ
Check out the ball joint replacement thread in the Super Duty tech folder.Great detailed write up with pics.
I would also look at your tie rod ends,sway bar and end link bushings,and what the heck,steering stabilizer.
Someone else will be here with more ideas.
Old Jan 3, 2009 | 08:35 AM
F350-6's Avatar
F350-6
If you're on a budget, make sure the ball joints are your problem first. I had to replace the front springs on my 2wd when the inside of the tires started wearing down.
Old Jan 3, 2009 | 11:18 AM
lhud's Avatar
lhud
If I remember correctly, my 2002, F250 sort of did the same thing. I had an alignment checked on it and was advised I need new shocks. Installed the Beilsteins (sp?) and things took a turn for the better.
Suggest checking your shocks.
Good luck,
Old Jan 3, 2009 | 02:34 PM
vans's Avatar
vans
I have replaced shocks with Bilstein, 10k ago,tires have 15k, I guess I should just have alignment checked and go from there
thanks for the input
Old Jan 3, 2009 | 02:40 PM
4inchlovin's Avatar
4inchlovin
If it is your ball joints make sure you move those front tires to the back right when you do the ball joints... When your ball joints go bad it tends to "feather" your front tires and feathered front tires will beat up ball joints.
Old Jan 3, 2009 | 02:41 PM
clintbonnie's Avatar
clintbonnie
What brand of tires are you running..? -
Old Jan 3, 2009 | 03:07 PM
DCSpecial's Avatar
DCSpecial
Is your truck 2wd?
Old Jan 3, 2009 | 03:34 PM
vans's Avatar
vans
I've got Firestone Transforce AT'S on it,( I live in a rural area and tire shop is two blocks away), I've been pretty good on rotating. Other than routine maintenance, I've never done anything major.
I plan to keep truck for anther 100k so I want to make sure everything is up to snuff.
Old Jan 3, 2009 | 03:37 PM
vans's Avatar
vans
Truck is 4 wheel, 2002 , I do pull a decent size boat, also been known to haul some firewood with trailer, other than that truck is used to commute to work and back.
