Air Bag Code
Old Jan 3, 2009 | 02:33 AM
azu's Avatar
azu
Air Bag Code
Once in a while I'll get the airbag light staying on. Today it came on while driving and I took note of the flashing to get the code. It is code 27. Anyone know what this would be? My guess is a bad electrical connection somewhere.
Old Jan 3, 2009 | 02:43 AM
azu's Avatar
azu
Search is indeed your friend.
Found the answer here https://www.ford-trucks.com/forums/7...bag-light.html
Old Jan 3, 2009 | 11:10 AM
Rockledge's Avatar
Rockledge
You can fix it yourself: https://www.ford-trucks.com/forums/s...45&postcount=4
Old Jan 3, 2009 | 12:30 PM
azu's Avatar
azu
Thanks! The light does work but I read a post, maybe yours, stating that even if the light lites it still may be a bad connector on one side of the bulb. This starting happening right after I changed my dash lights last year so I am leaning towards a loose connection somewhere.
Old Jan 3, 2009 | 01:08 PM
4.go's Avatar
4.go
I have a 2001 ranger 4x4 and mine did the same thing,there is a connecter under the drivers seat take apart and clean that should take care of tour problem.
Old Jan 3, 2009 | 04:30 PM
HomerWinzlow's Avatar
HomerWinzlow
When the code appears, see if the passenger air bag deactivation switch lamp is illuminating. That is the one down the center of your dash near the floor. If the yellow bulb in that switch fails or fails intermittently you can get this code.
Old Jan 3, 2009 | 06:06 PM
azu's Avatar
azu
I saw it was out today and tapped on it and it came on. There is my problem. I'll just replace the bulb as it probably has a loose connection there. Thanks everyone!!!
