Sponsored by: Kumho
Front springs
Old Feb 15, 2000 | 10:08 PM
MTN's Avatar
MTN
Front springs
I have a 86 F-150, can I put the front springs off a similar year F-250 on it? I can find these at wrecking yards pretty readily.
Old Feb 16, 2000 | 11:18 AM
swenson's Avatar
swenson
Front springs
The axle half's on the 150 are set up with coil spring perches with radius arms, the ones for the 250 are set up for leaf springs. It would take serious modification to switch from one type of spring to the other, otherwise you can swap the whole front suspension from a 250 into your 150, but then you might as well swap in a Dana 60 solid axle from the later 88 350. If your coils are sagging, either buy a new set or have a stronger set made for you by National Spring or someone else. You really can't swap the leaf springs in though.
Old Feb 16, 2000 | 02:37 PM
82F100SWB's Avatar
82F100SWB
Front springs
If it's a 2 wheel drive, the springs should fit, and the only difference is probably the spring rate, If it's a 4 wheel drive, as mentioned above, it's not fun.
Evan MacDonald
Old Feb 16, 2000 | 09:40 PM
MTN's Avatar
MTN
Front springs
Sorry, I forgot to tell ya it is a 2WD, would like to eventually swap in a 4WD axle tho. I am after the heavier spring rate and the little bit if extra lift
Old Mar 3, 2000 | 10:01 AM
Trail_Rider's Avatar
Trail_Rider
Front springs
Should be a real simple swap. I know they are interchangeable on 73-79 2 WD.
Trail Rider
Old Apr 21, 2000 | 08:10 AM
burton's Avatar
burton
Front springs
I have an 85 F150 2wd. Would this swap work for my truck to?
Old Apr 25, 2000 | 06:01 PM
82F100SWB's Avatar
82F100SWB
Front springs
Don't see why not, it should work.
Evan MacDonald
82 F100 FlareSide
300-6 NP435(6.69 low)
Steel Grey & Primer(can you say Fugly?)
Old Apr 26, 2000 | 11:53 AM
mrlaserboy's Avatar
mrlaserboy
Front springs
Reckless7
Jun 14, 2015 08:28 AM
Outlaw56
15
Sep 10, 2013 03:12 PM
VQT
Apr 5, 2012 08:57 AM
scoftheoaf13
Apr 4, 2012 05:15 PM
Pappys53
WTB - Parts & other
Nov 16, 2011 04:44 PM
