French Flathead WIP
Old Feb 24, 2009 | 07:57 PM
HD74's Avatar
HD74
Just got back from H&H in LA to see the engine run and it sounded fantastic and looked great considering it's in a test stand.
Old Feb 24, 2009 | 08:02 PM
HD74's Avatar
HD74
The rain shorten the running of the engine and kept pictures to a minimum.
Old Feb 24, 2009 | 08:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Very nice looking engine! Did they dyno it, or just do a test run?
19fifty4's Avatar
19fifty4
Nice. Very nice.
Old Feb 24, 2009 | 08:56 PM
HD74's Avatar
HD74
What Mike from H&H told me was they do a series of runs to heat up the engine and after cooling down they re-torque all the bolts check for leaks etc. They dial in the cab linkage, but no dyno runs.
Old Feb 25, 2009 | 08:12 PM
HD74's Avatar
HD74
Who makes the best performing headers for the F-1 and what about mufflers? The mufflers used on the test stand were Magnaflows anyone using them on their truck and what the best performance and sound distantance from the collector to the muffler?
Old Feb 25, 2009 | 10:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Flatties sound good with many combinations. I have Red's F-1 headers (3-into-1 exiting to rear), one of the few that clear the steering box on an F-1. I used his extensions which go from the headers to about the rear of the trans. I put Smithy's steelpaks on those. They sound great! and will sound better when I get tailpipes. Using the combo above, I was able to avoid any welding or fabrication, just slapped it together and waas on the road.
Old Feb 25, 2009 | 10:30 PM
HD74's Avatar
HD74
Are you going to run two inch pipe straight back?
I just want to say the pictures of the flatty don't do it justice.
Old Feb 26, 2009 | 04:49 PM
HD74's Avatar
HD74
This is what I'm replacing.
Old Feb 27, 2009 | 08:48 PM
eman92082's Avatar
eman92082
It's beautimous......
The sound of a Flat-Motor with mods is the best....
Second best is a high compression Jimmy with an open split manifold
Third best is a Y-Block of any vintage - they just have that Y-Block sound..... aaahhhhhhh .........
Just my two cents.....
Old Feb 27, 2009 | 11:21 PM
havi's Avatar
havi
I'll have the Roast Duck
I agree. I'll add an IH 345/392 V8 from 0-2000 rpms at a steady increase sounds good too.
Which brings me to this: When are the soundbites on this flat-motor, eh?
Old Feb 27, 2009 | 11:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
IMO 2-inch pipes are not good for anything and sound harsh. I also read a thread on the HAMB to the same effect, if you are on the street and running mufflers and tailpipes, 1-1/2" or at most 1-3/4" is better. Bigger is not always better, you need to maintain a certain velocity. These aren't 502 Chevies, they're relatively small engines.
Old Feb 27, 2009 | 11:51 PM
  #28
56 Sweety's Avatar
56 Sweety
Flat head Ford --makes a sweet little street machine.
Old Feb 28, 2009 | 12:28 AM
  #29
HD74's Avatar
HD74
I'm working on that
Old Feb 28, 2009 | 07:27 AM
  #30
HD74's Avatar
HD74
The video is a bit short but still Kool.
YouTube - P1010020
Turn up the volume!
