wiring help...please
Old Jan 2, 2009 | 02:01 AM
the glassman's Avatar
the glassman
its going on a 360 fe motor
basic points wiring
ill have a gm 1 wire alt so im just worried about the ignition system
Old Jan 2, 2009 | 02:31 AM
Hypoid's Avatar
Hypoid
Well yeah, that's the basic idea. What is the question?
Old Jan 2, 2009 | 02:36 AM
the glassman
the ? is ..................is this the correct wiring for a point system...
im not to familier with them
Old Jan 2, 2009 | 11:18 AM
Hypoid's Avatar
Hypoid
What you have diagramed will work.
Are you building from scratch, or using a stock harness?
If you are going into a stock Ford vehicle, the resistor is the wire that goes to the coil. The ignition switch is a multi-function. No push button needed if it works as designed.
