broken trac bar bracket
Old Jan 1, 2009 | 09:46 PM
sextons's Avatar
sextons
I have a 2003 LWB crew cab Powerstroke. We had heard some funny noise in the front end lately so took a look tonight. The trac bar mounting bracket on the axle is torn/fatigued into two pieces. The truck has a 4" lift and 209,000 miles on the clock. Since the bracket is welded to teh axle I guess we wil just weld it back in place. Has anyone seen this before?
Old Jan 1, 2009 | 10:18 PM
just another truck's Avatar
just another truck
do you have pictures?
Old Jan 1, 2009 | 10:23 PM
Tecman's Avatar
Tecman
Isnt there supposed to be a drop bracket for the track bar when you install a lift of that size? If it doesnt have it, that has to be ALOT of stress on that bracket to break it!
Old Jan 1, 2009 | 10:42 PM
DCSpecial's Avatar
DCSpecial
Even with a drop bracket the trac bar doesn't always line up perfectly. Hence why an adj. trac bar is always a nice upgrade.
The lower bracket has been known to break.....not very common through.
Old Jan 2, 2009 | 12:35 AM
Fordbronco69's Avatar
Fordbronco69
Infidel
Ide say it was either stressed to much(offroading) or it was weak from the start.
If you do weld it back up....put 1 or even 2 extra braces on it so you know it wont break again.....do it right the first time!
would love pictures
goodluck
