Vibration
Old Jan 1, 2009 | 07:33 PM
mercman78's Avatar
mercman78
Vibration
I Have A 2006 F150 Screw With 5.4 4x4.i Noticed On Long Uphill Grades,that At About 2200 Rpms At 50 Mph In 4th Gear That The Drive Train Seems To Vibrate.i Took It To The Dealer And Duplicated The Problem For Them.there Repair Was To "adjust" The Exhaust.i Still Feel This Vbration(in The Gas Pedel,steering Wheel And My A--!) And Have Taken It Back Again.but Now Thay Say There Is No Problem!!anybody Eles Have A Problem Like This?if So What Was The Fix.its Only In That Gear,speed And Rpm.as Soon As It Shifts Its Gone.thanks.
Old Apr 14, 2009 | 01:57 PM
Bob2626's Avatar
Bob2626
I have a f150 5.5 2wd, I have a vibration accelerating through 20 to 25 mph. Tow a trailer less than 5k and with a load in bed. not so noticeable when unloaded.
Dealer checked and found no fixes or reports on this problem, I now have 53k on the spedo it is a 2004
any help would be appreciated
Bob
Old Apr 14, 2009 | 03:40 PM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
ALLDATAdiy.com has a few TSB's about Vibrations at various speeds for your F150. Most of them start at the tires. Drive 20 miles at highway speeds. This will eliminate any flat spots on the tires from the vehicle sitting. After that look at balancing the tires. You may possibly have excessive runout.
Old Apr 14, 2009 | 03:43 PM
ALLDATAdiy INFO
Former Vendor
Bob
Is your F150 stock height? It sounds like your driveline angles might be off when towing as well.
Old Apr 14, 2009 | 07:32 PM
Bob2626's Avatar
Bob2626
vibration
Hi My f150 is stock height, noticed with different trailers and weights.using equalizer hitch.
Bob
Old Apr 15, 2009 | 11:46 AM
ggwash21's Avatar
ggwash21
Do any of you have limited slip? Its worth checking. My truck had the same vibs loaded and very little unloaded ended up being limited slip packings. Works great now...
grizzly11
28
Apr 20, 2011 01:31 PM
elee3
Mar 12, 2009 11:42 PM
Rayzfan
2004 - 2008 F150
83
Sep 16, 2005 04:31 PM
who
Aug 29, 2004 08:48 AM
02Lariat
Modular V8 (4.6L, 5.4L)
May 8, 2004 09:59 PM
