Trailer Brake Controller Question
Old Dec 31, 2008 | 08:03 PM
fourced4cyl's Avatar
fourced4cyl
I have been going through my recently purchased 2003 Excursion XLT V10 and one thing I have always questioned is the harness that seems like it should be hooked to a brake controller which is mounted below my dash. Im concerned that the stock trailer braking system is no longer working and I am going to tow my car in about a week to the race track. Can I just get a brake controller or is the harness propreitary to each trailer brake controller? There is also a small switch next to the harness that im not sure the function of. I have tried to trace back the wires but havent been able to get enough of the lower dash panels off yet. Any help is appreciated.
Thanks
Old Dec 31, 2008 | 08:28 PM
joe f350's Avatar
joe f350
frist check ur stock wireing frist my truck had a tailer brake at one point the guy i bought it off of took it off and know i have no brake lights rear blinkers or back up light
Old Jan 1, 2009 | 12:59 PM
3Mike6's Avatar
3Mike6
Unless you see a brake controller under the dash, you most likely do not have one. I know our '04 came with the "Trailer/Tow" package, but all there is, is the wiring and plug in at the bumper. I'm pretty sure you need to wire in your own controller....any will work, since the controller just needs a 12volt feed and ground, then the output goes to your harness labeled "trailer brakes".
Old Jan 1, 2009 | 06:38 PM
fourced4cyl
Ok sounds fairly simple. Hopefully the wiring that is under the dash is correct to the hitch plug. I will have to try to track down a controller locally for this week. Thanks
Old Jan 1, 2009 | 07:14 PM
3Mike6's Avatar
3Mike6
You should be able to find one at any Auto Parts store.
Just make sure it's an electric one, and has two controls - voltage ramp and applied voltage...most do now days though.
Old Jan 1, 2009 | 07:54 PM
conger's Avatar
conger
If the plug your describing is the one up and to the right of the gas pedal then you can usually pick up the mating end wire harness from the same place you get the controller from. Wiring instructions should come with both and they are pretty much standard in all Ford trucks. When I got my prodigy controller it came with a Ford harness. I simply matched up the colors of the wires as per the instructions and plugged it in. I keep a spare controller in the trailer in case this one ever quits working on a trip. All I have to do to change it is unplug one and plug the other in. I think there are also some wiring diagrams on FTE somewhere, probably in thee SD forum. Hope this helps.
Old Jan 4, 2009 | 05:19 AM
Mecinoid's Avatar
Mecinoid
Dang that reminds me I have to start working on the race car trailer.
Old Jan 5, 2009 | 04:01 AM
Stewart_H's Avatar
Stewart_H
Where do you live?
I have a Tekonsha Prodigy in my Excursion and like it a lot. I just recently purchased a PSD F250 and a Tekonsha Voyager was already installed in the truck, but I'm replacing it with another Prodigy to keep everything uniform.
The Voyager works flawlessly. So much so, I've procrastinated swapping it out for the new Prodigy controller I purchased back in November.
Drop me a PM if you're interested in my Voyager unit. It will come with a dedicated Ford wiring harness since I bought a new one to go with my Prodigy unit.
BTW, look for this plug under your dash. It's the tow harness you'll plug your braking unit into.
To orient yourself, that's looking from the drivers side, towards the center, next to where your right knee would be if you were driving, under and behind the radio and climate controls.
Stewart
