How do I test the EVP/EGR?
Old Dec 31, 2008 | 03:28 PM
C Holmes's Avatar
C Holmes
I have an 88 F 150 302 and I would like to test the EVP. I think the EGR itself is good as it is clean inside and the tures are new so not plugged. The solenoid on top of the EGR i assume is the EVP. How do I test this to make sure it is working? I don't have a vacuum tester but I have a volt meter. There appears to be no difference when I pull the vacuum line off the EVP at all. That is of course at idle. If I apply vacuum to the EGR from a line run from the intake she will stall instantly so I assume the EGR is free and working. Is there a simple test to make sure the EVP is functioning?
Old Jan 1, 2009 | 02:49 PM
Lazy K's Avatar
Lazy K
Go to the repair section of autozone.com and it will describe how to test it with a voltmeter. Good luck.
narcolepticpug
Electrical Systems/Wiring
Mar 23, 2009 12:52 PM
narcolepticpug
Mar 21, 2009 10:41 PM
Fordpup
Jul 21, 2007 08:02 AM
TrucksNamed"PHIL"
Apr 1, 2007 08:58 PM
tapenick
Aug 15, 2002 11:56 PM
