door wirring
Old Dec 31, 2008 | 12:38 PM
sailorjohn's Avatar
sailorjohn
door wiring
I'm swapping doors from a '92 E-150 to a '99 E-350 is there a plug/disconnect or do I need to cut and splice?
Old Dec 31, 2008 | 02:22 PM
Franklin2's Avatar
Franklin2
I looked at the 99 diagram, and there is a connector behind the kickpanel near the courtesy lamp, but I don't know if you will be able to get it through the hole in the door jamb.
Old Jan 1, 2009 | 06:24 AM
sailorjohn's Avatar
sailorjohn
Thank you, I found it after I cut the wires. That's what being impatient gets you. for those who might need this info later it is the kick-panel next to your outside foot as your sitting in the seat. On my van the divers side has the parking break release handle there. And yes the plugs do barley fit through the holes in the door jamb individually.
