89 Bronco won't stay running
Hello all,
I have been reading the posts for awhile and now have a question. I am helping a friend work on a 89 XLT with the 5.8L and E40D transmission. Anyway it seemed to have a bad in-line fuel pump, fuel gauge showed only the low flow working. I replaced the in-line pump, and it started right up and then proceeded to stumble and stall, once it warmed up. Now it will start rev up to 2000 RPM for 3-5 seconds and stop, and it won't turn over for a few more minutes. Following some of the other posts I replaced the filter, ICM, and ignition switch. The pressure gauge shows the in-line working and then it just drops off when the engine dies. I pulled the codes and all I got was the EVP circuit was out of limits. Any idea of where to proceed would be greatly appreciated.
I checked the pressure at the fuel rail and it passes the pressure test for the in-tank pump, and it also rises up with the frame rail pump. It starts nicely and idles and then dies out after 3-5 seconds or if you give it gas. Is there a switch from one circuit to another after the engine starts? I will also clean out the IAC this afternoon.
Thanks,
Thanks,
Another update the pressure at the rail is 30p.s.i. while idiling, and it stays within the boundaries when the throttle is opened. But then the pressure just drops off randomly. Could that be the fuel pressure regulator? I also cleaned out the mass airflow sensor and it seems to be working all right.
Acab1
10-09-2017 11:12 PM
'89F2urd
51
06-27-2017 06:38 AM
Shawn Paris
08-02-2016 10:56 PM
