Sponsored by: Real Truck
4x4 Trouble
Old Dec 29, 2008 | 09:15 PM
mikestoke's Avatar
mikestoke
Exclamation 4x4 Trouble
Hi all, I am having problems with my 4 x 4 in the automatic setting. When I throw the switch sometimes it will engage and sometimes it wont. I read somewhere if your having problems with a vacuum leak to throw your heater on and engage your 4 x 4 and if it switches to defrost that you have a leak. My question is how do you know if it is my front axle seals or the vacuum pump? I am getting a light on the dash but it is not engaging in less I get out and throw the hubs into manual position. Any help is greatly appreciated. The dealer wants around $100.00 to test it. But you all know how tight $$$ is this time of the year!! Thanks in advance.....Mike
Old Dec 29, 2008 | 09:26 PM
powerstroke72's Avatar
powerstroke72
Check out this post re: ESOF. May or may not be the case with yours but worth a try. Search a little further in the SD forum as there have been several recent posts on this. Good luck.
https://www.ford-trucks.com/forums/8...ging-esof.html
Old Dec 29, 2008 | 10:27 PM
Mike-11's Avatar
Mike-11
Mike, I had this same problem, yes it's true when you have a vaccum leak your floor heat will switch to defrost when you start driving on 4H. It will take about 1/4 to 1/2 mile and you will see the changes. I went under my truck today and followed all my lines. I notice one of my line was disconnected. After I hooked up the lines everything started to work correctly. Check your lines first and make sure there is no breaks in tube and connections. If everthing check out in your line then it might be the pump. also don't forget to check your fuses. I can't believe it was a disconnected tube. I hope this helps..
Old Dec 30, 2008 | 07:37 AM
mikestoke's Avatar
mikestoke
Thanks all for the info I will get out and see what I can find today. I will let you all know what I find. Again thank you for the help. Mike
RV_Tech
Electrical Systems/Wiring
Jul 6, 2013 09:53 PM
TL08
Sep 16, 2011 08:52 PM
cowboylelle
Oct 12, 2010 08:05 AM
bigboytoys08
Mar 3, 2010 10:56 PM
jdfield
Jan 3, 2005 07:25 PM
