Can to much oil in the engine damage anything?
I just checked my oil and its way over full.
Its up to the "T" in Operating.
About a inch up the dipstick from where it should be.
When the shop had my truck they must have put oil in it.
you should try and drain a little out so it reads good, the extra oil in the engine puts extra pressure on things like the rear main gasket and you dont want that to go.
YOU dont take it out, go in with the receipt, and tell someone to check your oil. Then Dont politely ask for your money back, tell them they need to drain 4 qts out and give your money back.
