Sorry for sounding a fool here, but isnt a tony wildman tunes kind of a custom thing? that being said, a tuner reprograms your truck to their settings..this would eliminate the tony wildman tunes.. you may want to contact tony wildman and see if you can purchase extra tunes from him.. it should be cheaper then buying a tuner..
What tunes do you have from Tony.
I would suggest adding some tunes to your chip depending on what you have now.
Edit: Also why are you wanting to stack two chips? Do feel you are not getting the power your after? It maybe time to upgrade a few other things if that is the case.
i was just curious. i have aggressive or 140hp whatever you would call it but my local truck shop that rebuilt my tranny said i can throw a diablo power puck? on it to get up to 220hp. but apparently its not true by the replies i got lol
Your probably sitting around the 300-310 hp now with your current setup. Definitely do not need to stack anything with a custom tune, won't do you any good.
If you want more HP, the next step would be either (no specific order implied) bigger injectors, HPOP upgrade, turbo, regulated return, etc.
