Sponsored by: Kumho
Will They Fit
Old Nov 27, 2000 | 07:17 PM
xtremetoyz_2000's Avatar
xtremetoyz_2000
Will They Fit
I have a 1992 Ford F-250 4x4 and I plan to purchase a 4 inch suspension lift by tough country and a 3 inch body will I be able to fit 38" Super Swamper TSL's or will I need more lift. I am running 32 x 11 tires stock and they don't rub. Thanks for any information.
Old Nov 30, 2000 | 05:43 PM
blacksheep30534's Avatar
blacksheep30534
Will They Fit
I dont think your tires are going to fit. From my past experience
you need 2.5 inchs of lift for every inch of tire above stock.
Thats a good rule of thumb.
Old Nov 30, 2000 | 10:48 PM
jopey's Avatar
jopey
Will They Fit
that doesn;t sound right. I mean my bronco has 27" stockers on it and if I wanted to put 44's on it that means I need 42.5" lift. I don't think they make them that big!
If it is still running. you didn't try hard enuf!
Old Dec 2, 2000 | 07:37 AM
blacksheep30534
Will They Fit
2.5 inchs is a little much, you could get away with 1.5
I do that so the tires dont rub on the fenders when fourwheeling. If you put a suspension and body lift its more like 1 inch lift, but I dont use lift blocks or body lifts
Its alot easier to go to a drivetrain shop order lifted
spring and get your drivelines extended at the same time.
I put 36 inch tires on a fullsize ford and never had any clearence problems. This way if I ever want to increase
tire size I wont need to lift it again.
Old Dec 3, 2000 | 01:43 AM
mrlaserboy's Avatar
mrlaserboy
Will They Fit
I'll start by telling you what I have. I've got a 6" suspension lift plus a 2" body lift for a total of 8" of lift on my Bronco. I run 38.5" Gumbo Mudders on the trail (actual loaded about 37" dia) and I do get some rubbing on the front edge of the rear wheel openings and on the rear corners of the front openings under compressed turns during extreme compression. Now, I am aware that F-250's can fit slightly larger tires than F-150's/Broncos with the same amount of lift. So, my advice is to take in consideration the actual measured tire sizes between different brands/types of tires and your type of wheeling. Oh, and tire width too. I have 15" wide tires, 38x12.5" tires wouldn't rub as much up front.
Dustin Siebert
mrlaserboy(No Email Addresses In Posts!)
Registry: http://www.superford.org/cgi-bin/sf.cgi?uid=default&vr2=1&ID=201
Home Page: http://www.fortunecity.com/silverstone/gear/40
'88 Bronco XLT 302EFI/AOD/BW1356/44IFS with 8 lugs(open)/10.25 FF(Lockright locker)/4.56/6" Superlift/2" BL/35's-street/38.5's-trails
2 BIG BRONCOS 4X4 CLUB - GREAT LAKES CHAPTER
http://www.superford.org/users/ylobronc/fest/chinamansgulchsmall.jpg
Old Dec 3, 2000 | 07:27 PM
Josh00's Avatar
Josh00
Will They Fit
ILuv4x4
Jun 28, 2014 05:22 AM
snozeuloze
Oct 24, 2008 09:00 AM
Scoop531
Apr 9, 2007 02:13 PM
552ford
Dec 4, 2003 10:09 PM
FordPickup460
Nov 28, 2003 12:09 AM
