Got really cold awhile ago, and started up my 91 one 4.0ltr ranger and i noticed it started leaking coolant. I've changed the thermostat, checked hoses, and changed the rad cap. I think one of the issues was a not so good coolant water mixture.. I started it up the other day and it looks like its leaking from everywhere under the engine its insane. I'm wondering what it could be. I've checked the oil numerous times for the milky look and nothing. Any ideas??? Let me know thanks
My 1990 radiator has the clamp on type tanks. They are leaking slightly. This might be the problem area. It only leaks when the coolant system is under pressure.
Either coolant is hitting the fan and looks like it's comming from all over the place or maybe a freeze plug has rusted out and it's comming out of the block, hopefully not, that would bite.
how hard is it to replace freeze plugs? This sounds like what it could be. Took it into a garage to see what they say but will most likely do the work myself. Thanks for the input..
I haven't had to replace a freeze plug since the late 70's. It was hard cutting the old one out, it took a hammer and chistle. The new one just tapped in with a hammer and wood block. It's a very tight fit.
I have a similar problem on my 98 Explorer V8 AWD. No leak from hoses. no water pump issue. 150k. just 10 yrs old. Did a pressure test today. No leaks. From the area (it is seeping from the back of the engine, coming down between the oil pan and the tranny pan), our best guess is a corroded freeze plug. Mine doesn't leak much. However, to get to it, we'll have to remove the transmission... not an easy task... They're looking to charge me $560. I'd do it myself, but dont' have the capability to remove the transmission.
Will probably get this done in a few weeks... meanwhile, any thoughts on what to update/service/maintain with the transmission, while it is out? the fluid gets changed regularly, and i have no leaks or issues. Anything else to work on, while it is out?
Throw a performance torque converter in there and maybe a shift kit while your playing. The improved performance would make it worth wild to have the freeze plug repaired ha ha.
I don't think I've had to replace one since the early 70's either. Went away to school and left my '65 289 Mustang in mom's garage. Came back at Christmas and found water all over the floor, one plug popped. It was such a PIA that I learned my lesson and made it a point to always buy anti-freeze after that, he he he...
Thats crazy, I also had to replace a freeze plug, but in a 67 mustang 289 back in 78. However, mine didn't pop, it got a hole in it. I wish it would of popped. The hardest part was getting the old one out.
Ha... that's too funny... Yes, no problem getting that one out, just had to grab it with a pair of pliers and pull a little! When I started the job, I had the optimistic idea that I was going to replace all of the plugs, just to be sure... Once I got under the car, on my back on the concrete floor of a freezing cold garage, I nixed that idea in a hurry... :-)
ouh yeah! ones I had to pull plug out for more then a half of day
Yeah, getting them out can be a job, they sieze in there tight. I had to cut it out with a hammer and chistle. You couldn't use that method on todays aluminum engines.
